Re: rear wings
[Re: Rich970]
#1095399
10/16/11 01:25 PM
10/16/11 01:25 PM
Posts: 52,972 Romeo MI
MR_P_BODY
i have a few questions about rear wings. what are the advandages of having one ? when is it nessary to have one ? what is the difference in styles like the ones with it spill plates ? thanks Rich
Shape of the back of the car makes a MAJOR difference, on my car it was day and night difference... my car doesnt have a long back end and the air was coming off the roof line and dropping about 6" behind the hatch cover... I was actually spinning on top end because the back was trying to lift... I added the wing and picked up 3 mph and control of the car... the spill plates hold the air on top of the wing instead of letting it fall off the sides... just like winglets on the ends of a airplane wing
Re: rear wings
[Re: Rich970]
#1095401
10/16/11 11:16 PM
10/16/11 11:16 PM
MR_P_BODY
MR P thanks for the reply . so far i have no top end traction or control or wandering problems. it is a 69 dart the trunk might be longer than yours. so is the gain from a rear wing mostly from beter traction and control ?
In my case it was traction... and in gaining traction I also gained a LOT more control
Re: rear wings
[Re: tubtar]
#1095403
10/17/11 01:37 PM
10/17/11 01:37 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
A wing will slow you down or so I have been told,have not tried my dragster with it off yet. If you have no handling or traction problems there is no need for one.
For some reason everyone has been having more problems this year with their cars wanting to wander,I had to put more angle in my wing because of that.I think it has a lot to do with the temp. being so much higher this year,I have seen the track temp. in the 140 degree range a good bit this year. The problem with a lot of door-cars doing that is the rear of the car sits a little higher than the front. A front air dam to keep as much air as possible from going under the car might be a better choice than a rear wing.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
Re: rear wings
[Re: MRMOPAR622]
#1095404
10/17/11 02:00 PM
10/17/11 02:00 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
Kind of funny. May or may not be realted. My buddy has a 68 Chevelle that runs in the heads up classses. Car goes 7.60's on drag radials with a big ole custom made wing on the back. We were in one of the finals & had starting issue (battery dead. Had to run back to trailer to get cables & jump started off of my golf cart. Took numerous attempts to try to start. Official's said time was up. Opponent took his time & idled up to the burnout box but did not do burnout. We finally got it fired & drove right up to the burnout box. Car had a lift off decklid with all of the strut supports rods holding it up. We did not have time to put it back together. Officials let us make the run with no deck lid. The car went 3 MPH faster than it ever has gone before. We won the race too. Won $1500, we gave $300 to the opponent for giving us the extra time. I am still up in the air if the truly work or not???? As mentioned body styles makes a difference too.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: rear wings
[Re: 6PKRTSE]
#1095406
10/17/11 07:33 PM
10/17/11 07:33 PM
Posts: 4,206 New York
polyspheric
New York
If the car over-steers (nervous), even if you don't lose traction, a wing may help but only if this happens at speed. If it always happens, look at weight dist., tire pressure, etc. first. If the car has neutral or slight under-steer at speed, the wing will slow you down and you gain nothing. A wing converts drag to down-force, more angle = more of both. Too much angle: the wing stalls and stops helping (but steals huge power). Too little angle: may even create lift, because the angle is NOT to horizontal but to the natural path of air coming off the roof. This is generally slightly down, so even a wing horizontal to the ground gives some drag. The best angle will vary with trap speed, you need more angle to get an effect in the 1/8 mile. If the car feels stable, crank the wing up 2° and see if your speed is up. If it still wanders or needs to be corrected, point the nose down 2°. Not to be obvious, but: if you do a 180°, the wing becomes a lift force and unloads the rear tires. Spill plates are for limited wing spans where more width is illegal or impractical.
Trivia: Mercedes had a large pop-up wing with very high angle attached to the rear deck of a 1955 (?) 300SLR roadster, activated by the brake pedal. Step down, the wing grabs lots of air and slows the car down. Similar to the dive brake on aircraft.
Boffin Emeritus
Re: rear wings
[Re: jcc]
#1095408
10/17/11 08:30 PM
10/17/11 08:30 PM
Posts: 694 Michigan
Super Scamp
I see my wing as :
1. 2.35 lbs over any fiberglass/steel decklid. 2. Down force @ 150+ mph helps at the big end, really helped at the track with a cross wind @ 20mph gusting. (Stayed in the groove) 3. Looks great and I know it works for the car.
Just One Man's Opinion
Mopar Mafia Racing
Re: rear wings
[Re: Gary Robbins]
#1095410
10/17/11 10:12 PM
10/17/11 10:12 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I thought the flat ones like the one on the above Barracuda were good pic nic tables, or shop benches ...LOL
I am truckless..
Re: rear wings
[Re: Gary Robbins]
#1095412
10/17/11 10:18 PM
10/17/11 10:18 PM
MR_P_BODY
On my car the back end always seemed loose at 135 mph but one day I had a 20mph quartering head wind and when I hit 135 the back lifted right off the ground... I ended up in the other lane just missing the other car so I put it in the trailer... come Monday I went to talk to the wind tunnel guys and they showed me some smoke footage of my body style... the air came off the roof line and dropped off the back end about 6"-8" behind the car... all of the area behind the roof line was a negative pressure and would try to lift the back end... after seeing that I went to the wing... I tried the spoiler style first with a adjustable upper so I could make it taller... that worked ok but the flatter longer wing worked better with less drag
Re: rear wings
[Re: jcc]
#1095413
10/18/11 12:11 AM
10/18/11 12:11 AM
polyspheric
New York
I'll be more careful not to post next time.
Boffin Emeritus
Re: rear wings
[Re: Rich970]
#1095416
10/18/11 08:45 AM
10/18/11 08:45 AM
MR_P_BODY
how do you tell the difference betwen a spoiler and wing ?
TO ME... the spoiler stuck UP into the air flow(like the spoiler on a old camero) and a wing was more horizontal with the air flow... a wing is usually longer... JMO
Re: rear wings
[Re: MR_P_BODY]
#1095417
10/18/11 10:21 AM
10/18/11 10:21 AM
Posts: 3,104 Wheels up, MO
nhramark
Wheels up, MO
At the NMCA finals in Memphis a few years ago, I messed up on a qualifying run and ruined the favorable index I had already established. (they lower your best et by .1 and that is your index)
Since the car wasn't fast enough to run the new index, we stripped it. Pulled the bumpers, tail light assemblies, carpet, door panels, wheelie bars, AND the rear wing. At almost 150 mph the Duster behaved exactly the same with or without the wing.
My wing is not that large, and Dusters have a pretty big decklid area so maybe that is why it didn't care about the change. I'm sure the body style has a huge effect on downtrack stability, maybe a bigger effect than the wing itself.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image]
9.100 @ 150 mph
5.780 @ 120 mph
