Engine Bay Firewall Wire loom Clips Coating?
#1093827
10/13/11 04:57 PM
10/13/11 04:57 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
Does any body have a cool easy tip to repair the coating on the fire wall wire loom clips , mine are falling apart and i would like to put a coating back on them before i repaint the engine bay on my SuperBee . I was thinking maybe the plastic pliers handle coating or flexible 3m heavy drip sealer smoothed with a finger. any Help here would be appreciated. Thank You CJ.
1969 Dodge Charger
1969 Dodge Superbee
Re: Engine Bay Firewall Wire loom Clips Coating?
[Re: cjs69mope]
#1093831
10/14/11 12:02 AM
10/14/11 12:02 AM
Posts: 392 Mississippi
lahatte
Mississippi
Maybe you can just replace them. I don't know if this will work for you, but... I bought a Goodmark firewall panel, and it had some goofy clips on it. On the original panel, I drilled the spotwelds from the back that held the original clips. On the Goodmark panel, I removed the goofy Goodmark ones and drilled a hole where the originals should go. Then, with a helper to hold them tight to the new firewall, I plug-welded the original clips on from the backside. So, if you have access to a doner car or firewall, or can find one, get the original clips from it (cut them out?) and use those. See... http://www.creative-machining.com/claylahatte//auto/1971cudaconv_java/#IMG_1891.jpgAlso, the previous few pictures.
[Re: lahatte]
#1093832
10/14/11 01:52 AM
10/14/11 01:52 AM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
...I used this stuff called Dip-it by Rustoleum. You can get it at HomeDepot or Lowe's. It works well but play with it first because it take a few times before you get it the way you want it.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
[Re: Troy]
#1093833
10/14/11 06:12 PM
10/14/11 06:12 PM
Posts: 289 Toronto, ON
ehbody
Toronto, ON
I used this stuff, I had it on hand from some tool handles I coat, and it look exactly like what I cut off the loom. Plasti-Dip
Shawn
70 AAR
[Re: ScottSmith_Harms]
#1093836
10/15/11 08:49 PM
10/15/11 08:49 PM
Posts: 2,431 USA
SSAAHemiFan
USA
Another trick is to get some black shrink tubing of a size that will stretch over the tab. Once in place heat it to shrink tight then neatly trim off the end flush or just over the end of the tab. THEN paint on a thin coat of plasti-dip over the top of the entire rubber areas and over the end a bit. It turns out looking very original with some practice.
