Putting A500 trany behind a 360. What parts do I need? #1093168
10/12/11 12:48 PM
10/12/11 12:48 PM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
I want to put a 518RH trany behind a LA360 engine. I already have a B&M flexplate to run a neutral balanced torque converter. Can someone tell me what torque converter will work with this set up? Will any 518 neutral balanced torque converter work? Thanks!
Re: Putting a 518 trany behind a 360. What parts do I need? [Re: dmerc] #1093169
10/12/11 01:02 PM
10/12/11 01:02 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You need to determine if the trans is lockup or not and get the appropriate style, other than that any neutral balance convertor will work.
Re: Putting a 518 trany behind a 360. What parts do I need? [Re: JohnRR] #1093170
10/12/11 01:42 PM
10/12/11 01:42 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
X2
And the OD unit needs to be changed a little. Call SMR trans and get the parts and modifications needed to the valve body so you don't kill OD.
I run an A500 behind a 360....
Re: Putting a 518 trany behind a 360. What parts do I need? [Re: JohnRR] #1093171
10/12/11 03:03 PM
10/12/11 03:03 PM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
Is there an easy way to tell if the trany is a lockup unit?
Re: Putting a 518 trany behind a 360. What parts do I need? [Re: Dragula] #1093172
10/12/11 03:06 PM
10/12/11 03:06 PM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
X2
Actually i think mine is an A500 unit also. The tag says its a special government spec trans. I'm not sure what that means.
Re: Putting a 518 trany behind a 360. What parts do I need? [Re: dmerc] #1093173
10/12/11 03:51 PM
10/12/11 03:51 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
yes , look at the input shaft , if the splines go to the end non lockup , it is has about .75- 1.0" of the end machined it's a lock up
Re: Putting a 518 trany behind a 360. What parts do I need? [Re: JohnRR] #1093174
10/12/11 04:05 PM
10/12/11 04:05 PM
IMGTX Offline
IMGTX  Offline
I look for an o-ring on the input shaft. O-ring = lockup, no o-ring (or groove for one) non lockup.
OD transmissions die from heat fast. Make sure you have a good cooler and not the stock in radiator one with the 5/16 lines. 3/8" lines minimum IMHO.
Re: Putting a 518 trany behind a 360. What parts do I need? [Re: dmerc] #1093175
10/12/11 06:38 PM
10/12/11 06:38 PM
Indiana
P
Pentastar440 Offline
P
Indiana
If the transmission has a two wire connector it is a non lockup, if it has a three wire connector it is a lockup.
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: Putting a 518 trany behind a 360. What parts do I need? [Re: dmerc] #1093176
10/12/11 07:07 PM
10/12/11 07:07 PM
MarkZ Online boogie
Worthy
MarkZ  Online Boogie
Worthy
You wrote in your first post that you already have the B&M plate for it. You'd better double check and figure out what transmission you have since the flex plates between the 500 and 518 transmissions are not interchangeable.
Re: Putting a 518 trany behind a 360. What parts do I need? [Re: IMGTX] #1093177
10/12/11 10:00 PM
10/12/11 10:00 PM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
Chrysler doesnt use o rings on input shaft.
Re: Putting a 518 trany behind a 360. What parts do I need? [Re: dmerc] #1093178
10/13/11 07:13 AM
10/13/11 07:13 AM
Dragula Offline
Dragula  Offline
X2
To tel if is a lockup style, the wired connector on it will either have two or three wires on it. Three wires is a lockup style.
Re: Putting a 518 trany behind a 360. What parts do I need? [Re: Dragula] #1093179
10/13/11 06:33 PM
10/13/11 06:33 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If it's a non-lockup 500 you can use any old 904 torq converter. If it's a non lockup 518 you can use a 727 torq converter. If it's a lockup trans, well them they need a lockup converter and a regular 904/727 converter won't work.
Re: Putting a 518 trany behind a 360. What parts do I need? [Re: MarkZ] #1093180
10/14/11 02:08 PM
10/14/11 02:08 PM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
OK, actually I have the B&M flexplate for a 904 transmission so... Are the torque converters different for the 904 and 500 trannies?
Re: Putting a 518 trany behind a 360. What parts do I need? [Re: dmerc] #1093181
10/14/11 03:17 PM
10/14/11 03:17 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
ALL 42RH/RE/A500 trannies are lockup.
in the '96 or so time frame the pump drive changed from 2 slots on the snout to 2 flats to reduce the propensity for the converter snout to crack. I'm using a lockup 904 converter with my A500...
why are you ditching the 700R4? the A500/518 is going to need crossmember and possibly floorpan mods to fit in an A...
2017 Grand Cherokee Overland
Re: Putting a 518 trany behind a 360. What parts do I need? [Re: patrick] #1093182
10/14/11 06:18 PM
10/14/11 06:18 PM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
Hey Patrick, not ditching the 700R4. This A500 is for my 1970 D100 truck. Need to get some better gas mileage! Thanks for the info guys. I thought all the A500 trannies were lock up too.
