Page 7 of 9 1 2 3 4 5 6 7 8 9
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1091026
12/14/13 01:52 PM
12/14/13 01:52 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I just cleaned up my coil bracket by soaking it in Evaporust. Looks to me like the bracket was originally dichromate finish. I can still see remnants of rainbow coloration. Am I correct?
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: FJR doc] #1091027
12/14/13 02:12 PM
12/14/13 02:12 PM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
It doesn't sound correct, post some pictures.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1091028
12/14/13 02:52 PM
12/14/13 02:52 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
Not the best pics but I the flash washed out some of the color.
Kevin
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: FJR doc] #1091029
12/14/13 02:52 PM
12/14/13 02:52 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
and here:
Kevin
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: FJR doc] #1091030
12/14/13 03:29 PM
12/14/13 03:29 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
As far as the coil bracket goes I have seen enough variable to say that is likely original. Silver to gold colored plating finishes varied A LOT on most small plated components, likely due to vendor or manufacturing batch to batch variables.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1091031
12/15/13 03:30 AM
12/15/13 03:30 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Ok, you made me go digging. I hoarded these coils up over the years. These are both from 71 Small blocks, the one dated 330 is from an early 71 340, the other might be from a 318, I'm not sure. They are identical in every aspect except the date codes (which are also pretty close). One of the brackets had a gold finish and one has a bracket with a silver finish, these have never been apart and enough original plating is visible to confirm both as genuine.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1091032
12/15/13 03:33 AM
12/15/13 03:33 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Both of these have "Made in Canada" embossed in the tops. They are also quite a bit shorter than the other 69/70 coils I have.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1091033
12/15/13 03:34 AM
12/15/13 03:34 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Showing the two shorter coils next to two of the longer ones.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1091034
12/15/13 03:36 AM
12/15/13 03:36 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Notice how the date codes run across the coils on the short versions and lengthwise on the taller coils. Also notice the gap in the part# ink stamping on the taller coils which is not present on the short coils.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1091035
12/15/13 03:37 AM
12/15/13 03:37 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Last one
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1091036
01/11/14 06:22 PM
01/11/14 06:22 PM
Lee Co. Fla.
5carguy Online content
5carguy  Online Content
Lee Co. Fla.
I would like to refresh this post for all the information that it is generating.
I would also like to add my engine to the others.
A little history of the car,
1971 Plymouth Cuda,Sassy grass Green 4 speed SPD feb 71
* means not original to engine
Engine color Orange
Block cast 8-30-70
Block assy info stamping CW340P34260406 assembled Dec 14,1970
Intake manifold cast date * 10-22-70
Waterneck 2780970
Oil pan stamped 294 no welded tabs
Temp sending unit stamped 250 date M1
Waterpump housing 2951698 Date 10-70
* Carb 4972S Date I 0
Heads J
That's all I have for now.
Can't figure out the date code on carb.
Thanks and hope this helps with the research,it is sure helping me.
Bob T.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: 5carguy] #1091037
01/11/14 07:22 PM
01/11/14 07:22 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Two items confuse me on that;
First the M1 temp sending unit sounds like December 1971, a year late?
The carb date code did not use an "I" because the skipped the letter "I" in the date coding. Post a pic of that one if you can. My guess is that it's an H or a J
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1091038
01/12/14 12:47 PM
01/12/14 12:47 PM
Lee Co. Fla.
Lee Co. Fla.
The temp unit must have been replaced at one time.After a better inspection of the date code of carb it is J 0.The carb is not original to this engine.The engine had aluminum valve covers on it and I will be going back with OEM covers.A question,what did the OEM cover bolts look like?Pictures would be great.Thanks for your input.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: 5carguy] #1091039
01/12/14 01:56 PM
01/12/14 01:56 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
There were various hardware vendors for engine bolts, I'm sure it varied year to year and assembly plant to assembly plant. Here is an example of an early 71 340. It is the only style I've seen from the Windsor plant on 71 340's.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1091040
01/12/14 08:20 PM
01/12/14 08:20 PM
Lee Co. Fla.
Lee Co. Fla.
Thanke You Scott for the picture,that helps a lot.I looked in my nut and bolt stash but couldn't find any.Anyone know where I can find a set?Also need oil pan bolts.
One more question,what is the carb date of J 0,and is it in the time frame for this assembled engine of Dec 14 70?
Thanks in advance
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: 5carguy] #1091041
01/12/14 08:37 PM
01/12/14 08:37 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Sorry, can't help you on the bolts. From what I've observed the correct bolts are not sold anywhere, you'll need to scrounge them off of similar vintage engines (not easy). Be forewarned, there various vendors on ebay and other places that sell "O.E." correct bolts and they have completely different markings. They may be right for some small blocks, some years, but when it comes to the original 70-71 340's I've seen, they are all wrong.
J = September 0 = 1970 = Perfectly acceptable on your December 14, 1970 assembled engine.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1091042
01/12/14 08:52 PM
01/12/14 08:52 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Oil pan bolt from a survivor 1971 340 assembled in September of 1970. Before removal:
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1091043
01/12/14 08:53 PM
01/12/14 08:53 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Since you can't see through road grime and corrosion I pulled one and bead blasted it, all have the same markings. Study closely, it's similar but NOT the same exact head markings as the valve cover bolts.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1091044
01/12/14 08:54 PM
01/12/14 08:54 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
After I replaced it
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1091045
01/13/14 11:43 AM
01/13/14 11:43 AM
Lee Co. Fla.
Lee Co. Fla.
Thank You again.I will continue my search for the right bolts.This is a fun project,and this post has helped me a lot.
