Page 6 of 9 1 2 3 4 5 6 7 8 9
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: kentj340] #1091006
11/30/13 03:06 AM
11/30/13 03:06 AM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
Could it have been identical to the S36 "E" bolt above?
I don't know but that's what my original 71 340 has, unpainted bolt and cable.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1091007
11/30/13 03:55 AM
11/30/13 03:55 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Thanks, Scott. And speaking of coils (other thread), my 69 340 coil (from a Hamtramck car delivered to Houston) was made in Canada. Never seen a Canadian repro offered...
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: kentj340] #1091008
11/30/13 04:16 AM
11/30/13 04:16 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Here's the original stencil marks.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: kentj340] #1091009
11/30/13 04:18 AM
11/30/13 04:18 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Another, slightly rotated.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: kentj340] #1091010
11/30/13 04:25 AM
11/30/13 04:25 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
And here's the totally anal question: What the heck is the meaning of a "10A" date code? The car was built November, 1968.
Could 10 be October and A stand for 1968?
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: kentj340] #1091011
11/30/13 11:49 AM
11/30/13 11:49 AM
Ohio
rck850 Offline
rck850  Offline
Ohio
Anybody know what was the original bolt head for a 69 turquoise 340 left head-to-neg batt cable? I know it was 5/16-18, S36 zinc dichromate yellow-rainbow finish, but I don't know the length, washer details, nor maker's mark.
Picture of bolt head. Might take longer for details
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: rck850] #1091012
11/30/13 12:18 PM
11/30/13 12:18 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
That's exactly the same battery cable bolt my 71 340 has. (I need 4 of these bolts in black or plated...Anyone?)
The only confirmed original 340 coil I have handy (71 vintage) has a date of 330 and does not have the "Made in Canada" or the 10A, but that could have easily been wiped off over the years.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1091013
11/30/13 01:03 PM
11/30/13 01:03 PM
Ohio
rck850 Offline
rck850  Offline
Ohio
This Dart that I have has never been apart. I am the third titled owner. It came from Florida is a non udercoat car and in decent shape really. It is a running and driving car, although at this time I'd need to spend a weekend going over mechanicals before I'd leave the drive. I'm pretty sure that if someone needs a picture of something original from a 69 GTS 340 Dart I could get it. If it was not for a repaint in the early 80's I would call it a survivor. The stripe is original and was masked off during the repaint. I have the build sheet and fender tag and all the numbers match motor, trans, body.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: rck850] #1091014
11/30/13 08:35 PM
11/30/13 08:35 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Cool, thanks! I see blue paint on the cable, which means the bolt used to have blue paint on it also. Looks like there were three identical 5/16-18 x 5/8 "E" bolts on the 69 340: R rear head to firewall ground, L front head to neg batt ground, and rear bolt on coil strap.
On your 69 GTS 340 Dart, I'd love to see good photos of the distributor clamp and the distributor.
Distributor clamp: It's well established these were copper plated, but I strongly suspect they were black in appearance due to a chemical process (hot alkaline dip?) known as copper blackening. I've never found any discussion about black clamps. Is your clamp black colored or copper colored? Warning - the blackened surface may be very thin and easily removed down to copper plating by mild abrasive scrubbing.
Distributor body: Is it a black painted iron casting? What is on the aluminum tag, and were tags different for manual and auto transmissions? I'd like to see a good photo of an original 69 340 4-speed tag.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: kentj340] #1091015
11/30/13 08:56 PM
11/30/13 08:56 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I can confirm that the clamps were copper clad then blackened. I have one that's about half worn to copper and another that's nearly all black. What I'd REALLY like to know is whether or not they were on the engine when it was painted, there may have been a year to year variable, as well and an engine plant variable such as when they went from orange to blue (Windsor to Mound Road) in late 1971. I have seen a pretty fair number with engine paint over spray, almost too many to write them all off as "day two" touch up over spray jobs.
Pic shows the clamps after I cleaned them up.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1091016
11/30/13 09:36 PM
11/30/13 09:36 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
Here's a pic of my 1970 Duster 340 distributor clamp. The engine was never apart until I took it apart at 135,000 miles. You can see remnants of orange paint on it.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: bremotorsports] #1091017
11/30/13 09:44 PM
11/30/13 09:44 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Here are the original coil bracket mounting bolts, which have already been re-plated per the as-originally-installed finishes.
First up is the front bolt:
Bill Rolik
Bill, what year, what color 340?
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: FJR doc] #1091018
11/30/13 09:44 PM
11/30/13 09:44 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
FJR, what is the bolt head marking? Any chance that orange paint could have rubbed onto the clamp from a freshly painted engine? Does it have any spray speckling?
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: ScottSmith_Harms] #1091019
11/30/13 10:25 PM
11/30/13 10:25 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
Scott, I can't tell from my pictures. I'll go out to the garage tomorrow and take a closer look in person.
Kevin
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: FJR doc] #1091020
12/01/13 09:52 AM
12/01/13 09:52 AM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
Here are close ups of the little bit of paint left on my clamp. The bolt is marked "E" with 3 lines.
Kevin
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: FJR doc] #1091021
12/01/13 09:53 AM
12/01/13 09:53 AM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
top
Kevin
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: FJR doc] #1091022
12/01/13 02:28 PM
12/01/13 02:28 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
FJR, yes it looks like over spray, albeit a very small amount. The head markings seem to have varied, the same bolts were likely used in other applications.
Speaking of that on the coil bolts, they were used elsewhere as well. My Federal Power Steering pump had this exact style bolt holding the reservoir can to the pump assembly.
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: kentj340] #1091023
12/01/13 04:25 PM
12/01/13 04:25 PM
New Jersey Bada Bing
bremotorsports Offline
71 340 in my convertible.
BS27H1B344342
SPD 3/31/71
Blue Mound Rd. engine.
Bill Rolik
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: bremotorsports] #1091024
12/10/13 09:59 PM
12/10/13 09:59 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I cleaned my distributor clamp off of rust by soaking in Evaporust. Very little of of the original copper plating remained afterwards. Anybody have suggestions of how to duplicate the blackened appearance? I thought about gun bluing but just wanted to see if anybody has any other suggestions.
Kevin
Re: Warning! Totally Anal Long Winded O.E. 340 Thread! [Re: FJR doc] #1091025
12/10/13 10:04 PM
12/10/13 10:04 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Try dipping it in Eastwood blackening solution and sealing it with something like RPM
