Re: Warning! Totally Anal Long Winded O.E. 340 Thread!
[Re: ScottSmith_Harms]
#1091036
01/11/14 06:22 PM
01/11/14 06:22 PM
Posts: 2,405 Lee Co. Fla.
5carguy
Lee Co. Fla.
I would like to refresh this post for all the information that it is generating. I would also like to add my engine to the others. A little history of the car, 1971 Plymouth Cuda,Sassy grass Green 4 speed SPD feb 71 * means not original to engine Engine color Orange Block cast 8-30-70 Block assy info stamping CW340P34260406 assembled Dec 14,1970 Intake manifold cast date * 10-22-70 Waterneck 2780970 Oil pan stamped 294 no welded tabs Temp sending unit stamped 250 date M1 Waterpump housing 2951698 Date 10-70 * Carb 4972S Date I 0 Heads J That's all I have for now. Can't figure out the date code on carb. Thanks and hope this helps with the research,it is sure helping me. Bob T.
#1091040
01/12/14 08:20 PM
01/12/14 08:20 PM
5carguy
Lee Co. Fla.
Thanke You Scott for the picture,that helps a lot.I looked in my nut and bolt stash but couldn't find any.Anyone know where I can find a set?Also need oil pan bolts. One more question,what is the carb date of J 0,and is it in the time frame for this assembled engine of Dec 14 70? Thanks in advance
