Re: Warning! Totally Anal Long Winded O.E. 340 Thread!
[Re: kentj340]
#1091006
11/30/13 03:06 AM
11/30/13 03:06 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Could it have been identical to the S36 "E" bolt above?
I don't know but that's what my original 71 340 has, unpainted bolt and cable.
[Re: ScottSmith_Harms]
#1091007
11/30/13 03:55 AM
11/30/13 03:55 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Thanks, Scott. And speaking of coils (other thread), my 69 340 coil (from a Hamtramck car delivered to Houston) was made in Canada. Never seen a Canadian repro offered...
[Re: kentj340]
#1091008
11/30/13 04:16 AM
11/30/13 04:16 AM
kentj340
Cut and Shoot, TX
Here's the original stencil marks.
[Re: kentj340]
#1091009
11/30/13 04:18 AM
11/30/13 04:18 AM
kentj340
Cut and Shoot, TX
Another, slightly rotated.
[Re: kentj340]
#1091010
11/30/13 04:25 AM
11/30/13 04:25 AM
kentj340
Cut and Shoot, TX
And here's the totally anal question: What the heck is the meaning of a "10A" date code? The car was built November, 1968.
Could 10 be October and A stand for 1968?
[Re: kentj340]
#1091011
11/30/13 11:49 AM
11/30/13 11:49 AM
Posts: 1,385 Ohio
rck850
Ohio
Anybody know what was the original bolt head for a 69 turquoise 340 left head-to-neg batt cable? I know it was 5/16-18, S36 zinc dichromate yellow-rainbow finish, but I don't know the length, washer details, nor maker's mark.
Picture of bolt head. Might take longer for details
[Re: rck850]
#1091014
11/30/13 08:35 PM
11/30/13 08:35 PM
kentj340
Cut and Shoot, TX
Cool, thanks! I see blue paint on the cable, which means the bolt used to have blue paint on it also. Looks like there were three identical 5/16-18 x 5/8 "E" bolts on the 69 340: R rear head to firewall ground, L front head to neg batt ground, and rear bolt on coil strap.
On your 69 GTS 340 Dart, I'd love to see good photos of the distributor clamp and the distributor.
Distributor clamp: It's well established these were copper plated, but I strongly suspect they were black in appearance due to a chemical process (hot alkaline dip?) known as copper blackening. I've never found any discussion about black clamps. Is your clamp black colored or copper colored? Warning - the blackened surface may be very thin and easily removed down to copper plating by mild abrasive scrubbing.
Distributor body: Is it a black painted iron casting? What is on the aluminum tag, and were tags different for manual and auto transmissions? I'd like to see a good photo of an original 69 340 4-speed tag.
