Roller Lifters #1086462
10/01/11 06:58 PM
10/01/11 06:58 PM
Brisbane Australia
572B1 Offline OP
572B1  Offline OP
Brisbane Australia
Could somebody help me out here. I have a mopar performance mega block, the old style and i am after a set of roller lifters that clear the lifter bores.
I wan't solid body for std chrysler oiling to the rocker gear, pressure feed to the roller, and extended body so the guide bars clear the lifter bores without machining.
I am after brands, part numbers and any info. thanks in advance rob.
Re: Roller Lifters [Re: 572B1] #1086463
10/01/11 07:20 PM
10/01/11 07:20 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I went through the same thing when Isky came out with the red zones I ended up with Comp 848 which is an AMC application.It has EDM oiling and the hole in the pushrod seat for pushrod oiling if you want to use it.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Roller Lifters [Re: hemi-itis] #1086464
10/01/11 07:46 PM
10/01/11 07:46 PM
Brisbane Australia
572B1 Offline OP
572B1  Offline OP
Brisbane Australia
Thanks Al, Have you got a picture of the lifter body. What lift cam are you using and how is your oil pressure.
Re: Roller Lifters [Re: 572B1] #1086465
10/01/11 10:56 PM
10/01/11 10:56 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
829's Comps will defiantly work... I went through this with my World Hemi block.
I scored these PBM lifters for well under $300, they are made by Morel, and are really good lifters for the money, but I couldnt run them for this very reason.
Re: Roller Lifters [Re: Bob_Coomer] #1086466
10/02/11 12:39 AM
10/02/11 12:39 AM
Brisbane Australia
572B1 Offline OP
572B1  Offline OP
Brisbane Australia
Thanks Bob, Its hard to get info on this subject.
anyone else.
Re: Roller Lifters [Re: 572B1] #1086467
10/02/11 01:01 AM
10/02/11 01:01 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I can get Crane lifters that will work for that application.
RIP Monte Smith
Re: Roller Lifters [Re: CompWedgeEngines] #1086468
10/02/11 01:47 AM
10/02/11 01:47 AM
Brisbane Australia
572B1 Offline OP
572B1  Offline OP
Brisbane Australia
Hi Todd, I have sent Chase Knight a pm about the 66554-16 Crane ultra-pros and waiting on a reply. Are they what you have in mind.
Rob.
Re: Roller Lifters [Re: 572B1] #1086469
10/02/11 07:15 AM
10/02/11 07:15 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
here is a pic of the crane ultra pros in my world block...
Mopar Performance
Re: Roller Lifters [Re: moparniac] #1086470
10/02/11 08:02 AM
10/02/11 08:02 AM
Brisbane Australia
572B1 Offline OP
572B1  Offline OP
Brisbane Australia
Thanks for the pictures sledgehammer. Are they the 66554-16 lifters.
Re: Roller Lifters [Re: 572B1] #1086471
10/02/11 06:56 PM
10/02/11 06:56 PM
Brisbane Australia
572B1 Offline OP
572B1  Offline OP
Brisbane Australia
