Re: Roller Lifters
[Re: 572B1]
#1086463
10/01/11 07:20 PM
10/01/11 07:20 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I went through the same thing when Isky came out with the red zones I ended up with Comp 848 which is an AMC application.It has EDM oiling and the hole in the pushrod seat for pushrod oiling if you want to use it.
Re: Roller Lifters
[Re: hemi-itis]
#1086464
10/01/11 07:46 PM
10/01/11 07:46 PM
Posts: 855 Brisbane Australia
572B1
Brisbane Australia
Thanks Al, Have you got a picture of the lifter body. What lift cam are you using and how is your oil pressure.
Re: Roller Lifters
[Re: 572B1]
#1086465
10/01/11 10:56 PM
10/01/11 10:56 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
829's Comps will defiantly work... I went through this with my World Hemi block. I scored these PBM lifters for well under $300, they are made by Morel, and are really good lifters for the money, but I couldnt run them for this very reason.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
Re: Roller Lifters
[Re: Bob_Coomer]
#1086466
10/02/11 12:39 AM
10/02/11 12:39 AM
572B1
Brisbane Australia
Thanks Bob, Its hard to get info on this subject.
anyone else.
Re: Roller Lifters
[Re: 572B1]
#1086467
10/02/11 01:01 AM
10/02/11 01:01 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I can get Crane lifters that will work for that application.
RIP Monte Smith
Re: Roller Lifters
[Re: CompWedgeEngines]
#1086468
10/02/11 01:47 AM
10/02/11 01:47 AM
572B1
Brisbane Australia
Hi Todd, I have sent Chase Knight a pm about the 66554-16 Crane ultra-pros and waiting on a reply. Are they what you have in mind.
Rob.
Re: Roller Lifters
[Re: moparniac]
#1086470
10/02/11 08:02 AM
10/02/11 08:02 AM
572B1
Brisbane Australia
here is a pic of the crane ultra pros in my world block...
Thanks for the pictures sledgehammer. Are they the 66554-16 lifters.
