bb or sb turbo a body #1086211
10/01/11 03:04 AM
10/01/11 03:04 AM
central Pa.
71Pan Offline OP
71Pan  Offline OP
central Pa.
any bb manifolds that would work in a body
any sb manifolds that would work in a body
have a bunch bb stuff but if a small block is less hassle to turbo ai will go that route. I am going turbo dont know what direction?? car is painted dana 60 built with 4.10 that will need to be changed. I woul like the car to run 10.0 cars 1s 3400 28 tall tire caltracs and caged. I have a steel 4.0 stroke sb crank and a 71 360 block please give me your input this is all new to me but awesome.A car you can actually drive and is fast WOW
Re: bb or sb turbo a body [Re: 71Pan] #1086212
10/01/11 09:56 AM
10/01/11 09:56 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
The B/RB will require cutting up the engine compartment. If that doesn't bother you, go for it. The package will be VERY tight under the hood.
Turbo power is less about the inches and more about the heads. Go with the combination that has the best heads.
- Stu Harmon
Re: bb or sb turbo a body [Re: 71Pan] #1086213
10/01/11 10:17 AM
10/01/11 10:17 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what he said. BB will give you much more power but it will require more "cutting" than a SB.
Coming soon!!!!
Re: bb or sb turbo a body [Re: feets] #1086214
10/01/11 11:13 AM
10/01/11 11:13 AM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
X2!!
I went the single T6 and regret it! Large 5" dp was a beeatch to get out the engine compartment. I did it with cutting the apron. Much easier to go twins, small or big block is your choice. Definitly easier to get two 3" dp out than the 5"....
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: bb or sb turbo a body [Re: CUUDAK] #1086215
10/01/11 11:18 AM
10/01/11 11:18 AM
NC
SLOW67 Offline
SLOW67  Offline
NC
X2!!
My SB was hard enough to fit in the engine bay and my 3.5 dp had to exit out the fenderwell like header. With my patience a BB would have been out of the question If you had a FULL cage and could loose your inner fenderwells it would probably be easier
Re: bb or sb turbo a body [Re: 71Pan] #1086216
10/01/11 02:50 PM
10/01/11 02:50 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
The hot rod's engine compartment is not much bigger than an A body's. It took lots of time to lay this thing out. I ended up cutting holes in the aprons and sticking the turbos half under the fenders.
- Stu Harmon
Re: bb or sb turbo a body [Re: feets] #1086217
10/01/11 04:04 PM
10/01/11 04:04 PM
mid-mich
turboplymouth Offline
mid-mich
I went with a bb for the higher HP capability (as far as OEM blocks are concerned). I think I would do a sb for a big single, or do twins next time for fitment issues.
'72 Scamp, 3500#, 440, S400, blowthrough, meth. inj. 9.78 @ 139 so far at 12 psi, 11.00 @ 131 on real street tires.
Re: bb or sb turbo a body [Re: turboplymouth] #1086218
10/07/11 09:34 PM
10/07/11 09:34 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
The BB is a much stouter package as far as the skirted block and 5 bolts/cyl instead of SB's 4.
There are a few guys that have been very successful with fast SBs, though, so it's not a cut/dry rule.
But in an A-body, I think a SB is much more likely to reach completion and be a better-engineered package on the first shot.
consider also that if you get 200 more HP from a BB it means nothing unless you get it to the ground, so there's more weight and expense and chassis setup.
K.I.S.S.
Re: bb or sb turbo a body [Re: Fury Fan] #1086219
10/12/11 11:16 AM
10/12/11 11:16 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
if you build headers a low deck in an abody will fit with out any cutting of the wells, but im not sure if you are wanting to build headers
Re: bb or sb turbo a body [Re: joshking440] #1086220
10/12/11 11:22 AM
10/12/11 11:22 AM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
I am looking to sell my 2" low deck turbo headers and crossover pipe with t-6 flange, 2 60 mm wastegates all stainless steel.
One day I will have something cool here.
Re: bb or sb turbo a body [Re: joshking440] #1086221
10/12/11 04:44 PM
10/12/11 04:44 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
how can he run a turbo and not build custom headers?
Re: bb or sb turbo a body [Re: Mr.Yuck] #1086222
10/12/11 08:39 PM
10/12/11 08:39 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Factory exhaust manifold turned around. But he needs to have stock exhaust bolt pattern on the heads he chooses. Me I would do a small block, you only want to go 10.0s and that is easy to do with the small block.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: bb or sb turbo a body [Re: 1967dartgt] #1086223
10/12/11 09:38 PM
10/12/11 09:38 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
one can go 10's with a fairly mild N/A BB.
Re: bb or sb turbo a body [Re: Mr.Yuck] #1086224
10/12/11 11:04 PM
10/12/11 11:04 PM
IN
ahy Offline
ahy  Offline
IN
The OP said a car you can actually drive and is fast... an A with a turbo SB is certainly fast. An A with a BB can be fast but doesn't drive so well. A BB is a lot of weight in an A.
I'd go SB to keep weight down with better fit an important bonus.
Re: bb or sb turbo a body [Re: Mr.Yuck] #1086225
10/12/11 11:33 PM
10/12/11 11:33 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
You can go 9.90s with a indy headed sb N/A too(ask me how I know). But OP said turbo is what he wants.
Re: bb or sb turbo a body [Re: 1967dartgt] #1086226
10/16/11 01:26 PM
10/16/11 01:26 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I'm notta turbo guy but will suggest a roll cage that will cert to 8.50.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: bb or sb turbo a body [Re: hemi-itis] #1086227
10/16/11 02:33 PM
10/16/11 02:33 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
"You can go 9.90s with a indy headed sb N/A too"
It sure can be done! Im curious as to the gearing, converter, cam, compression.
Re: bb or sb turbo a body [Re: TheOtherDodge] #1086228
10/17/11 05:56 PM
10/17/11 05:56 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
You'll need much more cam, much more compression, much more stall and much more gear w/ the SB.
The good thing about boost is you don't need any of that. Buddy ran 8.44 @ 174 w/ his S/B (396) turbo car w/ 3.73 rear.
Re: bb or sb turbo a body [Re: Mr.Yuck] #1086229
10/17/11 11:21 PM
10/17/11 11:21 PM
Houston, Texas
Houston, Texas
BINGO!
In about 3 to 4 weeks I will post the results of my passes with a stock block, home ported Eddy heads, 220/.520 hydrualic cam, 3.55 gear, 2500 converter, pump gas, shifting at 6000 rpms.
Re: bb or sb turbo a body [Re: TheOtherDodge] #1086230
10/25/11 09:21 PM
10/25/11 09:21 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
5500 stall,3.91 gear,28x10.5 tire through full exhaust 3000lb 9.62 on pump gas sb o yea indy headed
