remove rust floor pan (small area) #1085184
09/29/11 03:19 PM
09/29/11 03:19 PM
Bellevue,Mich.
Dodge33 Offline OP
Dodge33  Offline OP
Bellevue,Mich.
hello,I GOT SOME surface rust on a small area(passenger front
floor pan from window being left down,the person I bought the car
from did not think is was important to roll up the window) I did not
want to media blast inside because the rest of the floor has good paint on it.
what can I use to eat the rust? thanks for any help
Re: remove rust floor pan (small area) [Re: Dodge33] #1085185
09/29/11 04:13 PM
09/29/11 04:13 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Make a dam around the area out of clay and pour some Evaporust inside and let it sit for a day or so.
Re: remove rust floor pan (small area) [Re: Neil] #1085186
09/30/11 02:59 AM
09/30/11 02:59 AM
SeventySatellite Offline
After Evaporust can you just clean and prep for epoxy?
Re: remove rust floor pan (small area) [Re: SeventySatellite] #1085187
09/30/11 03:14 PM
09/30/11 03:14 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Evaporust leaves behind a sricky film on sheet metal.
I'd wipe it down with reducer and then sctotchbrite pad some PPG DX metal prep over the area before painting.
