Any dodge techs? 04 stratus #1084379
09/28/11 04:58 PM
09/28/11 04:58 PM
Round Rock,Tx
N
Nirvana Offline OP
Nirvana  Offline OP
N
Round Rock,Tx
Hey guys-
My brother has a 2004 Dodge Stratus 4 door with the 2.4 and automatic. It has just over 100,000 miles on it and he never had the fluid/filter replaced. The car ran great and shifted fine,the fluid was just a little dirty.
I just pulled the pan,and replaced the filter. Re filled it with the proper ATF+4. No leaks,and got it filled up to the proper level. Now it upshifts great and feels very smoothe.
The problem is after getting up to speed and comming to a stop,at about 30 mph the downshift into first is very harsh/clunky. Any idea what this could be?
87 D100 225 4 speed.
Re: Any dodge techs? 04 stratus [Re: Nirvana] #1084380
09/28/11 05:33 PM
09/28/11 05:33 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
They actually had problems with the pumps that would cause that. I bet it is the 4/3 downshift as all the customers also thought it was the shift back into first. If you know anyone with a scanner have them reset the QuickLearn. If not you can try unhooking the battery for about 10 minutes. The TCM has an adaptive memory as it will learn how you drive it and adapt how the shift solenoids apply the clutches. Usually if that fixes it for a while and then if it does it again then it may need a pump. The problem with the pump is delayed engagement at times into first gear which is applying the underdrive clutch. The delay causes the CVI count to go up as the trans will adapt to how fast the underdrive clutch applies. And since it runs the CVI count up it will apply underdrive harder when its not delayed any. When the trans downshifts from 4th to 3rd the underdrive clutch gets engaged and it usually bangs in which causes the banging on the downshift. But try and get the Quicklearn set and then see how it does after that. See if the banging comes back in a week or so. If not then dont worry about it. Its best to have the QuickLearn set with a scanner. Ron
Re: Any dodge techs? 04 stratus [Re: Nirvana] #1084381
09/28/11 05:34 PM
09/28/11 05:34 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Had the same problem with my brothers van.Seems the trans fluid was the wrong type.Pulled the pan and refilled with proper fluid and was good.Sounds like you used the proper fluid though.Anymore you have to read the dip stick to find out what they use.Rocky
Chrysler Firepower
Re: Any dodge techs? 04 stratus [Re: Nirvana] #1084382
09/28/11 05:41 PM
09/28/11 05:41 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
1st - if it's going all the way down to 1st gear from 4th - you have a problem - modern electronic trans down shift just like they up shift - one gear at a time.
If , it's CVI learning process issue it'll fix itself in time.
If it's not , you'll find out soon enough
Re: Any dodge techs? 04 stratus [Re: 383man] #1084383
09/28/11 06:30 PM
09/28/11 06:30 PM
Round Rock,Tx
N
Nirvana Offline OP
Nirvana  Offline OP
N
Round Rock,Tx
Ron-
Thank you I will give that a try.
I used Mopar ATF+4 so I know its the right fluid. I dont thinks its going from 4th to 1st,it happens when the car gets to about 30 mph on decel. I think Ron hit it on the head.
Jared
Re: Any dodge techs? 04 stratus [Re: Nirvana] #1084384
09/28/11 08:37 PM
09/28/11 08:37 PM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
383man/Ron nailed it! I have done many front pumps on 41TE transmissions. I believe 04/05 were the suspect years.
Re: Any dodge techs? 04 stratus [Re: Nirvana] #1084385
09/28/11 08:53 PM
09/28/11 08:53 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
No it is going from fourth to third. The same clutch comes back on in third (direct clutch) as it is also on in first. First is the direct clutch and the low/reverse clutch and fourth is the overdrive clutch and 2/4 clutch. Third it the overdrive clutch and the direct clutch and it is the direct clutch that will run the cvi's high if it is delayed in first sometimes. It wont learn to fix itself if it has that problem. Thats why setting the Quicklearn resets all the clutch cvi's and will make the direct clutch come on normal. It will learn to apply faster (harder) if the pump causes the delay and does not apply the direct clutch right away. It uses pressure switches to know when the clutches apply and if one takes to long it will cycle the solenoid faster to apply it faster which when it applies to fast it will bang. Good luck , Ron
Re: Any dodge techs? 04 stratus [Re: 383man] #1084386
09/28/11 08:57 PM
09/28/11 08:57 PM
Round Rock,Tx
N
Nirvana Offline OP
Nirvana  Offline OP
N
Round Rock,Tx
I know,I was responding to another member who thought I said it was going from 4th to first.
Re: Any dodge techs? 04 stratus [Re: Nirvana] #1084387
09/28/11 10:42 PM
09/28/11 10:42 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Sorry about that didnt mean no disrespect. Ron
Re: Any dodge techs? 04 stratus [Re: 383man] #1084388
09/28/11 10:55 PM
09/28/11 10:55 PM
Round Rock,Tx
N
Nirvana Offline OP
Nirvana  Offline OP
N
Round Rock,Tx
No worries at all Ron! I appreciate your help .
I confirmed your advise that it is the 4-3 downshift. I had him put it in 3rd and drive around,and he said the problem went away. I am going to disconect the neg. batt cable and see if it helps,if not I will hook it up to a scanner.
Jared
Re: Any dodge techs? 04 stratus [Re: Nirvana] #1084389
09/29/11 12:40 AM
09/29/11 12:40 AM
Round Rock,Tx
N
Nirvana Offline OP
Nirvana  Offline OP
N
Round Rock,Tx
Well,seems to be ok now after leaving the batt cable unhooked for a bit. Hopefully the problem wont come back. Thanks again for the help
Re: Any dodge techs? 04 stratus [Re: Nirvana] #1084390
09/29/11 10:26 AM
09/29/11 10:26 AM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
You need to do a quick learn. Same thing happened to my 02. Was going from 4th to 3rd so hard, I thought for sure it was going to break something. Took about a minute with the DRB and it was back to normal.
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
