Re: Most economical method to lower a B-body
[Re: NTOLERANCE]
#1083833
11/21/11 12:10 AM
11/21/11 12:10 AM
Posts: 669 Michigan, USA
ramman5600
Michigan, USA
Can you explain your thinking?
*Sigh*
Lowering blocks will increase your rear axles distance from the leaf spring, thereby creating a lever effect, that will INCREASE the possibility of wheel hop and or traction loss.
Thanks for sharing your actual thought - at least you shared some logic instead of just assuming everyone knows everything about suspension like Mont-Claire and therefore we should just shut down the internet and Moparts because apparently everyone has all the answers now or are mind readers when someone post a statement like " don't do this or that". ![](/ubbthreads/images/graemlins/image_294343.gif)
[Re: ramman5600]
#1083835
11/21/11 11:23 AM
11/21/11 11:23 AM
Posts: 7,982 Scranton, PA
Montclaire
Scranton, PA
I could go on for paragraphs and people would still use lowering blocks, I didn't feel like getting into it. It's the reason that JC Whitney is still in business, and can continue to sell helper leafs, air shocks, and light up donkey hood ornaments. Some people will insist that they do things the right way, and some will go the other route, but hey, it's a big world with a lot of things happening, and it doesn't matter much at the end of the day.
