Page 1 of 3 1 2 3
Most economical method to lower a B-body #1083792
09/27/11 07:11 PM
09/27/11 07:11 PM
Michigan, USA
ramman5600 Offline OP
Michigan, USA
I don't want to create a low rider, but just drop the car about 2". I know there are a lot of great options for replacement parts to really make the car handle (70 SuperBee), but is there a safe yet economical way to accomplish a 2" drop without spending $2500? Thanks in advance for the advice.
-C
Re: Most economical method to lower a B-body [Re: ramman5600] #1083793
09/27/11 07:17 PM
09/27/11 07:17 PM
IN
ahy Offline
ahy  Offline
IN
Safe, low cost and 2" drop. I think you can pick 2 out of the three.
For a 1" drop, turn down the T bars and get the rear springs re-worked by a local spring shop. Cutting down the bump stops would be helpful. A stiffer set of front bars would be nice to prevent bottoming but may not be strictly necessary. Cost <$1,000 even with new T bars.
For 2" I really think you would need drop spindles and maybe flipped rear springs. I personally would worry about exhaust and oil pan bottoming with a 2" drop.
Re: Most economical method to lower a B-body [Re: ahy] #1083794
09/27/11 09:39 PM
09/27/11 09:39 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
14" low profile tires....
You didn't say it had to look good!
Re: Most economical method to lower a B-body [Re: RodStRace] #1083795
09/27/11 10:29 PM
09/27/11 10:29 PM
Michigan, USA
Michigan, USA
I was actually considering an 18" wheel and tire combo. Does anyone have the pan clearance issue that was noted?
-C
Re: Most economical method to lower a B-body [Re: ramman5600] #1083796
09/27/11 10:43 PM
09/27/11 10:43 PM
IN
ahy Offline
ahy  Offline
IN
20 or 22" tires look much better. More seriously, what are your objectives? Handling, like the low look ect?
I've got my 70 E lowered a little (probably 3/4") with 1" T bars and stiff shocks. My 17" tires are on the short side with 25" diameter. I have a Hemi pan which is about 1" deeper than stock and a K frame mounted skid plate to protect the pan. The skid plate has earned its keep. I've had to touch up the paint on it at least twice after meaningful contact. It is sometimes driven with "spirit" on real midwest roads.
Re: Most economical method to lower a B-body [Re: ahy] #1083797
09/27/11 11:07 PM
09/27/11 11:07 PM
Michigan, USA
Michigan, USA
I just like the wheels to fill the wheel well without too much space above the tire. I thought about the 26" wheels, but the 1/4" of rubber for tire was a detractor. Anyway - I also like the shorter side wall (45-50 aspect ratio) for steering response and with the newer tire tech they can actually make a nice riding tire.
-Chad
Re: Most economical method to lower a B-body [Re: ramman5600] #1083798
09/27/11 11:28 PM
09/27/11 11:28 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
Have my sister-in-law sit in it
Sorry I could`nt resist
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Most economical method to lower a B-body [Re: 6bblFLASH] #1083799
09/27/11 11:56 PM
09/27/11 11:56 PM
Michigan, USA
Michigan, USA
Re: Most economical method to lower a B-body [Re: ramman5600] #1083800
09/28/11 10:45 AM
09/28/11 10:45 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
instead of softening up your ride get a set of roadrace torsion bars and back off a little on those--for the rear use a 1 inch spacer between the axle and spring perch----bob
Re: Most economical method to lower a B-body [Re: 6bblFLASH] #1083801
09/28/11 10:48 AM
09/28/11 10:48 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Most economical way is to let the air out of the tires, to adjust ride height.... ...I couldn't help myself either, he did want the cheapest way to accomplish this...
Re: Most economical method to lower a B-body [Re: DAYCLONA] #1083802
09/28/11 01:13 PM
09/28/11 01:13 PM
dogdays Offline
dogdays  Offline
The old trick, several forklift batteries in the trunk!
Sorry, I couldn't help it.
R.
Re: Most economical method to lower a B-body [Re: dogdays] #1083803
09/28/11 04:25 PM
09/28/11 04:25 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
i know that the magnum force 2" dropped leaf springs are just springs that dont have a much of a arch to them giving them that 2" u need...now got get them rearched!
Re: Most economical method to lower a B-body [Re: dangina] #1083804
09/28/11 04:37 PM
09/28/11 04:37 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
It's sort of tough to recommend without knowing: the tire diameters you have, your current gap/distance between the lower control arm bumpsptop and frame, and your k-frame and exhaust to ground clearance.
Just lower the front T-bar down to drop the tops of the front wheel lips 1" from current height. Check LCA bump stop clearance. If the LCA bump stop gap is too small buy the Energy suspension flat poly bumpstops.
In the rear buy Doctor Diff adjustable front spring hanger. That give you something like 1" or 2" drops
I forgot how much the Doctor Diff hangers are, but I don't think that and the bump stops are too much money.
Re: Most economical method to lower a B-body [Re: ramman5600] #1083805
09/28/11 04:44 PM
09/28/11 04:44 PM
BC, Canada
Black_Bee Offline
Black_Bee  Offline
BC, Canada
For the front, I turned down my 1" torsion bars, and for the rear, I used some spring hangers that Mancini sells:
http://chucker54.stores.yahoo.net/manciniracing20.html
I got a 1.5-2" drop which is pretty much required if you want to run the larger wheels.
Paul
'69 Super Bee 383 EFI Turbo
Re: Most economical method to lower a B-body [Re: Black_Bee] #1083806
09/28/11 07:46 PM
09/28/11 07:46 PM
Michigan, USA
Michigan, USA
If your ID picture is of the car which you did this too, then that is exactly what I am looking for. Thanks
Re: Most economical method to lower a B-body [Re: ramman5600] #1083807
09/28/11 07:54 PM
09/28/11 07:54 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Not that major an operation to make some lowering blocks. Retains most of your ride. Some 2 1/2 inch wide heavy wall tubing the Height of which would be the distance that you want to drop the rear. 2 pieces about 6" long and drill press. Drill out one side a hole the diameter of the spring tie bolt head to sit in and drill a 5/16 inch hole directly opposite to install a short spring eye bolt to fit in the centering hole in the spring perch.
Re: Most economical method to lower a B-body [Re: ramman5600] #1083808
09/29/11 12:35 AM
09/29/11 12:35 AM
BC, Canada
Black_Bee Offline
Black_Bee  Offline
BC, Canada
Before drop... looks pretty good.
Paul
Re: Most economical method to lower a B-body [Re: Black_Bee] #1083809
09/29/11 12:35 AM
09/29/11 12:35 AM
BC, Canada
Black_Bee Offline
Black_Bee  Offline
BC, Canada
After drop... much better!
Paul
Re: Most economical method to lower a B-body [Re: Black_Bee] #1083810
09/29/11 12:42 AM
09/29/11 12:42 AM
BC, Canada
Black_Bee Offline
Black_Bee  Offline
BC, Canada
FYI, that's a 295-40-18 on the rear. It's actually a bit taller than the 275-60-15s that I had on before, but for some reason, the gap with those 15s didn't look bad.
Paul
Re: Most economical method to lower a B-body [Re: Black_Bee] #1083811
09/29/11 01:15 AM
09/29/11 01:15 AM
5th and plum
redmist Offline
redmist  Offline
5th and plum
Turn down torsion bars, and flip the factory hangers upside down.
Page 1 of 3 1 2 3
