LA/Magnum Crosswind Intake Manifold #1083498
09/26/11 11:31 PM
09/26/11 11:31 PM
sw mo
meanmothermagnum Offline OP
sw mo
Has anybody tried running a Crosswind Intake manifold on a magnum engine and compared it to the standard barrel manifold? I am thinking of getting one for my 5.2 and just wondering if there are any gains to be had by the switch?
Re: LA/Magnum Crosswind Intake Manifold [Re: meanmothermagnum] #1083499
09/27/11 12:12 AM
09/27/11 12:12 AM
IN
ahy Offline
ahy  Offline
IN
The Crosswind is a bigger performance manifold and the barrel is tuned to match the cam and give the 5.2 as much low/mid range torque as possible. If its computer controlled the Crosswind will throw off the fueling.
Unless you are changing the cam and re-programming the ECU or adding a carb and conventional ignition, I'd leave it alone.
Re: LA/Magnum Crosswind Intake Manifold [Re: ahy] #1083500
09/27/11 01:02 AM
09/27/11 01:02 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
The beer keg, barrel intake is made for maximum torque in a truck application. They were made to get heavy loads moving from a dead stop. And the Crosswind (and Eddy) intakes are made for maximum horsepower in performance applications, to get lighter loads moving as quickly as possible.
If your vehicle is mostly stock (truck?), probably best to stay with the barrel intake unless you are ready to commit to a performance vehicle instead of maximum grunt.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: LA/Magnum Crosswind Intake Manifold [Re: meanmothermagnum] #1083501
09/27/11 11:09 AM
09/27/11 11:09 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
yes, you will gain some upper rpm horsepower, but might be disappointed at a possible loss in bottom end torque.
EFI engines dont seem to care as much, but as described earlier, without any other modifications like a cam, heads etc...the barrel intake is definitley part of a well matched factory combo.
