Manual Steer box ? ID... good from bad. #1083172
09/26/11 07:59 PM
09/26/11 07:59 PM
Gateway to the West.
hemi_harvester Offline OP
I have heard there are to differnt manual steering boxes but they both look the same how can you tell the good from the bad ?
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
Re: Manual Steer box ? ID... good from bad. [Re: hemi_harvester] #1083173
09/27/11 12:07 AM
09/27/11 12:07 AM
I had heard that the /6 ones are not as stout as V8 ones something about a bushing being used instead of a bearing but not sure. Might inquire at www.slantsix.org or www.forabodiesonly.com or www.bigblockdart.com. I think it is a non issue & if the play is acceptable you're in good shape but then there's the prob of the horrendous 24:1 EDIT iirc there's a difference on the outside case that will tell if it's the bushing or the bearing type, would need to search that out
