Re: Oil pan removal in an A-body?
[Re: Jim_Lusk]
#1082836
09/26/11 10:11 AM
09/26/11 10:11 AM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
I dropped the pan on the 340 in my GTS many years ago. Unbolt the motor mounts and raise the engine (I seem to recall putting a 2x4 under each mount). I cannot remember if I undid the pitman arm and idler arm or not, but probably.
Same here , lift the engine and I remember pulling the centerlink .
[Re: JohnRR]
#1082837
09/26/11 11:20 AM
09/26/11 11:20 AM
Posts: 15,487 Florida
scratchnfotraction
same here I did it in the 68Dart with a 73 k frame,droped the header on both sides and pull pass side all the way out,then the whole tie rod/center linke came out,then raised engine,droped oil pump/pick up into the pan,removed pan.I may even had to roll the throws on the crank to walk it out.
header sux on A-bodys and so does the R&R of the oil pans
[Re: 300by500]
#1082838
09/26/11 10:24 PM
09/26/11 10:24 PM
Posts: 2,511 Tampa , Fl
MoparJoe
super gas
super gas
Tampa , Fl
I would pull the motor if it were mine, done it many of times.
You can leave the hood on and the radiator in it too, I unbolt the exhaust and tie it back to the shocks, drop the starter, pull the plugs and oil filter, pull the harmonic balancer and dist, unbolt the converter, stick a floor jack under the trans then unbolt the motor from the trans and the mounts, after that the motor comes straight up and out.
If you have access to a lift I might try doing it in the car but I can usually have the motor out in 45min or so the other way.
