Page 2 of 3 1 2 3
Re: AAR and T/A Guys Check It Out!!!! [Re: Troy] #108192
08/22/08 11:08 AM
08/22/08 11:08 AM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
Here is a breather that I got from Napa. In the instruction sheet it says "When used on a 1970, 1971 Plymouth T/A and Dodge AAR Barracuda cap off nipples that are not needed.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: AAR and T/A Guys Check It Out!!!! [Re: Troy] #108193
08/22/08 11:47 AM
08/22/08 11:47 AM
WI
RestoRick Offline
RestoRick  Offline
WI
Wow... that thing has more nipples hangin' out than a strip club...
Re: AAR and T/A Guys Check It Out!!!! [Re: Troy] #108194
08/22/08 12:47 PM
08/22/08 12:47 PM
N. Dak.
RareTA Offline
super street
RareTA  Offline
super street
N. Dak.
Mine has two.
'09 Challenger R/T '70 Challenger T/A 340 6Pak and Auto I was born with nothing and I still have most of it left!
Re: AAR and T/A Guys Check It Out!!!! [Re: Troy] #108195
08/22/08 01:04 PM
08/22/08 01:04 PM
Chicago, IL
Moparman440 Offline
Moparman440  Offline
Chicago, IL
Now that was funny. Thanks for the laugh !
Re: AAR and T/A Guys Check It Out!!!! [Re: Troy] #108196
08/22/08 03:38 PM
08/22/08 03:38 PM
Lancaster Pa
Transamcuda Offline OP
Lancaster Pa
Wasnt there a guy in Ca. sellign NOS ones of those Troy??!! :P
Home of the AAR Registry
www.transamcuda.com
Re: AAR and T/A Guys Check It Out!!!! [Re: RareTA] #108197
08/22/08 04:15 PM
08/22/08 04:15 PM
cataclysm80 Offline
cataclysm80  Offline
Mine has two.
Any idea if it came that way from the factory?
Did it have two on it when you found it?
Have you traced the history?
Tav
Re: AAR and T/A Guys Check It Out!!!! [Re: Transamcuda] #108198
08/22/08 04:57 PM
08/22/08 04:57 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
Wasn't there a guy in Ca. selling NOS ones of those Troy??!! :P
Yes there was!! But I sold this repop one to a guy in Santa Barbara CA. with the initials D.F. It was the only way to make him happy.
Re: AAR and T/A Guys Check It Out!!!! [Re: Troy] #108199
08/22/08 06:04 PM
08/22/08 06:04 PM
.....I vote for three!!
cucu,don't cap off the nipple on the carb. It could cause fuel starving on the top end.
doesnt the vent also go to the stud hole in the center of the carbs air horn? so even if it was capped off the gas would vent there?
I'll have to check mine. I thought thats the way hollys were made
Re: AAR and T/A Guys Check It Out!!!! #108200
08/22/08 06:29 PM
08/22/08 06:29 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
If you block off that nipple you can starve the bowl of fuel.
Re: AAR and T/A Guys Check It Out!!!! [Re: Troy] #108201
08/22/08 09:18 PM
08/22/08 09:18 PM
I think you're wrong on that one.If you replace the bowl with the standard bowl with the rubber vent cap on the same carb,you would basicly have the same carb without a vent tube.Also,some 69 1/2 and early 70's big block carbs have no venting at all.
Re: AAR and T/A Guys Check It Out!!!! #108202
08/23/08 02:20 AM
08/23/08 02:20 AM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
....don't the 69 1/2 center carb have a flapper door on top of the bowl??
Re: AAR and T/A Guys Check It Out!!!! [Re: Troy] #108203
08/23/08 07:50 AM
08/23/08 07:50 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Some do,some don't.All 69 1/2"s.
Re: AAR and T/A Guys Check It Out!!!! [Re: 62maxwgn] #108204
08/23/08 10:28 AM
08/23/08 10:28 AM
Pennsylvania
A0M397X Offline
A0M397X  Offline
Pennsylvania
Here is a picture of a car that was discussed a few months back. 6K original miles. This breather looks similar.
Also of interest to me in this magazine car is the valve cover. There were discussions about the different part numbers for the AAR/TA valve cover as opposed to the standard 340. From the limited view here, this passenger side one seems to have the loom mount on the valve cover top further back as would be expected of the AAR/TA specific type.
No TV Party Tonight
Re: AAR and T/A Guys Check It Out!!!! [Re: cataclysm80] #108205
08/23/08 10:32 AM
08/23/08 10:32 AM
N. Dak.
RareTA Offline
super street
RareTA  Offline
super street
N. Dak.
Mine has two.
Tav
I cannot honestlly say. The guy I got the car from had it since 73 and had many different engines in it over the years. He had it till 1990 when I bought it from him. It was never painted but he did hold on to the origional engine. When I got it the OEM engine was setting on his shop floor and another junkyard 340 was in the bay also blowen up. The valve covers on it now were the ones that were on it when I bought it. But it must be taken with a grain of salt 'cause who knows after this many years and engine changes.
Re: AAR and T/A Guys Check It Out!!!! [Re: RareTA] #108206
08/23/08 12:32 PM
08/23/08 12:32 PM
Lancaster Pa
Lancaster Pa
That is another misleading item from the parts book. Just because the parts book list something doesnt mean its gospel. Theres TONS of stuff the parts book lists that they never even made or used, but its in there. a few years ago Jerry Lebar was nice enough to let me use his AAR to show that there is no difference or clearence issues. In fact at the time I had 3 different types of 70 340 valve covers and the differences between them is actually an inch or less. I have seen many original untouched cars and I have seen both versions time and time again. Not to hijack my own thread but I will post a few of those pix. This is another example of a thread discussion that has been discussed over and over again and should have been archived for times like this.
www.transamcuda.com
Re: AAR and T/A Guys Check It Out!!!! [Re: Transamcuda] #108207
08/23/08 12:33 PM
08/23/08 12:33 PM
Lancaster Pa
Lancaster Pa
2
www.transamcuda.com
Re: AAR and T/A Guys Check It Out!!!! [Re: Transamcuda] #108208
08/23/08 12:34 PM
08/23/08 12:34 PM
Lancaster Pa
Lancaster Pa
3
www.transamcuda.com
Re: AAR and T/A Guys Check It Out!!!! [Re: Transamcuda] #108209
08/23/08 12:38 PM
08/23/08 12:38 PM
Lancaster Pa
Lancaster Pa
www.transamcuda.com
Re: AAR and T/A Guys Check It Out!!!! [Re: Transamcuda] #108210
08/23/08 12:42 PM
08/23/08 12:42 PM
Lancaster Pa
Lancaster Pa
The wire trough on the bottom was broken off but you tell by the spot welds its placement was different than the top one. This was actually the valve cover off Jerry Lebars AAR. I let him borrow one of mine till he finds one to replace it.
www.transamcuda.com
Re: AAR and T/A Guys Check It Out!!!! [Re: Transamcuda] #108211
08/23/08 12:44 PM
08/23/08 12:44 PM
Lancaster Pa
Lancaster Pa
www.transamcuda.com
Page 2 of 3 1 2 3
