Re: AAR and T/A Guys Check It Out!!!!
[Re: Troy]
#108192
08/22/08 11:08 AM
08/22/08 11:08 AM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
Here is a breather that I got from Napa. In the instruction sheet it says "When used on a 1970, 1971 Plymouth T/A and Dodge AAR Barracuda cap off nipples that are not needed.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
[Re: Troy]
#108195
08/22/08 01:04 PM
08/22/08 01:04 PM
Posts: 234 Chicago, IL
Moparman440
Chicago, IL
Now that was funny. Thanks for the laugh ! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Troy]
#108196
08/22/08 03:38 PM
08/22/08 03:38 PM
Posts: 2,340 Lancaster Pa
Transamcuda
Lancaster Pa
Wasnt there a guy in Ca. sellign NOS ones of those Troy??!! :P
[Re: RareTA]
#108197
08/22/08 04:15 PM
08/22/08 04:15 PM
Posts: 4,165 Florida
cataclysm80
Mine has two.
Any idea if it came that way from the factory? Did it have two on it when you found it? Have you traced the history?
Tav
[Re: Troy]
#108199
08/22/08 06:04 PM
08/22/08 06:04 PM
.....I vote for three!! ![](/ubbthreads/images/graemlins/biggrin.gif)
cucu,don't cap off the nipple on the carb. It could cause fuel starving on the top end.
doesnt the vent also go to the stud hole in the center of the carbs air horn? so even if it was capped off the gas would vent there?
I'll have to check mine. I thought thats the way hollys were made
#108200
08/22/08 06:29 PM
08/22/08 06:29 PM
Troy
West Coast, CA
If you block off that nipple you can starve the bowl of fuel.
[Re: Troy]
#108201
08/22/08 09:18 PM
08/22/08 09:18 PM
I think you're wrong on that one.If you replace the bowl with the standard bowl with the rubber vent cap on the same carb,you would basicly have the same carb without a vent tube.Also,some 69 1/2 and early 70's big block carbs have no venting at all. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Troy]
#108203
08/23/08 07:50 AM
08/23/08 07:50 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
....don't the 69 1/2 center carb have a flapper door on top of the bowl??
Some do,some don't.All 69 1/2"s. ![](/ubbthreads/images/graemlins/scope.gif)
[Re: 62maxwgn]
#108204
08/23/08 10:28 AM
08/23/08 10:28 AM
Posts: 672 Pennsylvania
A0M397X
Pennsylvania
Here is a picture of a car that was discussed a few months back. 6K original miles. This breather looks similar.
Also of interest to me in this magazine car is the valve cover. There were discussions about the different part numbers for the AAR/TA valve cover as opposed to the standard 340. From the limited view here, this passenger side one seems to have the loom mount on the valve cover top further back as would be expected of the AAR/TA specific type.
No TV Party Tonight
[Re: RareTA]
#108206
08/23/08 12:32 PM
08/23/08 12:32 PM
Transamcuda
Lancaster Pa
That is another misleading item from the parts book. Just because the parts book list something doesnt mean its gospel. Theres TONS of stuff the parts book lists that they never even made or used, but its in there. a few years ago Jerry Lebar was nice enough to let me use his AAR to show that there is no difference or clearence issues. In fact at the time I had 3 different types of 70 340 valve covers and the differences between them is actually an inch or less. I have seen many original untouched cars and I have seen both versions time and time again. Not to hijack my own thread but I will post a few of those pix. This is another example of a thread discussion that has been discussed over and over again and should have been archived for times like this.
