Re: High Volume Oil Pump on stock engine rebuild?
[Re: RapidRobert]
#1081477
09/24/11 03:31 PM
09/24/11 03:31 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
Car will mainly be driven to car shows and cruise ins.
std vol/psi. If you had extensive oiling enlargement mods/large clearances then yes a hi vol/psi but your app it costs a bit of horsepower which is not a deal breaker but stresses the inter shaft hex more which is important. A std Sealed Power unit taken apart/clearance checked/cleaned will work fine
been using a standar pump for 10 years on my 400hp 360, stock pan, 25 hot 65psi over 1500 rpm 15w/40w oil
[Re: dobie]
#1081481
09/24/11 10:56 PM
09/24/11 10:56 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I put an HV pump in each of my builds. Never a problem with it, or the drive.
[Re: Cab_Burge]
#1081483
09/25/11 12:49 AM
09/25/11 12:49 AM
Posts: 893 Tustin, CA
pishta
Tustin, CA
My vote is for Std. pump.
12 Grand Caravan 06 T&C 02 T&C 96 Breeze 65 Barracuda "S"
