High Volume Oil Pump on stock engine rebuild? #1081474
09/24/11 02:27 PM
09/24/11 02:27 PM
Detroit, MI
FC7AARcuda Offline OP
Detroit, MI
I am rebuilding my '71 340 engine. For the most part it is a stock rebuild with a slightly larger cam. Should I use a stock oil pump or a high volume oil pump? Years ago, I was told not to use a high volume oil pump for a street motor. Car will mainly be driven to car shows and cruise ins. What do people recommend?
Re: High Volume Oil Pump on stock engine rebuild? [Re: FC7AARcuda] #1081475
09/24/11 02:30 PM
09/24/11 02:30 PM
Eden, Texas
Strawdawg Offline
Strawdawg  Offline
Eden, Texas
standard pump should be fine
Steve
Re: High Volume Oil Pump on stock engine rebuild? [Re: FC7AARcuda] #1081476
09/24/11 02:35 PM
09/24/11 02:35 PM
std vol/psi. If you had extensive oiling enlargement mods/large clearances then yes a hi vol/psi but your app it costs a bit of horsepower which is not a deal breaker but stresses the inter shaft hex more which is important. A std Sealed Power unit taken apart/clearance checked/cleaned will work fine
Re: High Volume Oil Pump on stock engine rebuild? [Re: RapidRobert] #1081477
09/24/11 03:31 PM
09/24/11 03:31 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
been using a standar pump for 10 years on my 400hp 360, stock pan, 25 hot 65psi over 1500 rpm 15w/40w oil
Re: High Volume Oil Pump on stock engine rebuild? [Re: ademon] #1081478
09/24/11 04:06 PM
09/24/11 04:06 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
HighVolume is overkill for most street motors. I take it apart a Standard Pressure pump, clean up the casting flash in the passages, round any sharp corners, check clearances and reassamble with a HighPressue spring.
Re: High Volume Oil Pump on stock engine rebuild? [Re: FC7AARcuda] #1081479
09/24/11 09:10 PM
09/24/11 09:10 PM
GMP440 Offline
GMP440  Offline
A stock volume pump is all you need.
Re: High Volume Oil Pump on stock engine rebuild? [Re: GMP440] #1081480
09/24/11 10:38 PM
09/24/11 10:38 PM
Ohio
dobie Offline
dobie  Offline
Ohio
Is there any harm by using one? Two years ago when I did my 383 I put one in. No issues so far, but these last two years have only seen about 40 total miles.
1968 Plymouth Road Runner 383 4 speed
Re: High Volume Oil Pump on stock engine rebuild? [Re: dobie] #1081481
09/24/11 10:56 PM
09/24/11 10:56 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I put an HV pump in each of my builds. Never a problem with it, or the drive.
Don't be the exception.
Re: High Volume Oil Pump on stock engine rebuild? [Re: dobie] #1081482
09/25/11 12:30 AM
09/25/11 12:30 AM
The A motors don't have the oiling issues that the B and RB motors do so there is no need for a high volume oil pump on a stock street driven SB, 318, 340 or 360
Re: High Volume Oil Pump on stock engine rebuild? [Re: Cab_Burge] #1081483
09/25/11 12:49 AM
09/25/11 12:49 AM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
My vote is for Std. pump.
12 Grand Caravan
06 T&C
02 T&C
96 Breeze
65 Barracuda "S"
