My Solution For The Rear Six Pack Carb Idle Screws! #1081095
09/23/11 07:19 PM
09/23/11 07:19 PM
So. Cal. For Now But Texas Bou...
69sixpackbee Offline OP
I was just goofing around yesterday in the shop and I decided to make an easier and cheaper solution to the hard-to-reach rear carb idle screws on the Six Pack setups. Those of you who know what I am talking about can appreciate this!
I am too cheap to buy the high-dollar "Competitors"
re-designed baseplate with the relocated screw location so I set out for an alternative. I took a pair of 8-32x1"lg. 316 stainless set screws and machined my own replacement mixture screws. It is much easier to get at them being that it is a 3/32" hex. I made a quick and dirty ball-end driver so that I can make adjustments with ease! I backcut the ball-end relief some more so I can get at them at about a sixty-degree angle. I have a long version that I put the hex wrench into a 1/4" diameter MDS-filled nylon "handle" which is nothing more than drilling a pilot hole and then heating up the wrench and melting it into the stock. I put an index mark on it so I could monitor the movement accurately. The second iteration is the same concept but with a stiff spring as a compliant joint to gain access with an even more acute angle.
Works like a charm!
I just thought I would share it with you guys!
Regards,
Bud
Re: My Solution For The Rear Six Pack Carb Idle Screws! [Re: 69sixpackbee] #1081096
09/23/11 07:46 PM
09/23/11 07:46 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
AWESOME, thanks for sharing!
Ray
Re: My Solution For The Rear Six Pack Carb Idle Screws! [Re: 69sixpackbee] #1081097
09/23/11 09:28 PM
09/23/11 09:28 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Great Idea Bud! ....are you going to "market" those?
Re: My Solution For The Rear Six Pack Carb Idle Screws! [Re: DAYCLONA] #1081098
09/24/11 03:10 AM
09/24/11 03:10 AM
Never really thought about it. I guess I could help out those who need it.
Re: My Solution For The Rear Six Pack Carb Idle Screws! [Re: 69sixpackbee] #1081099
09/24/11 11:04 AM
09/24/11 11:04 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Nice Bud Those "other plates" are complete garbage. Machine quality just sucks... good idea just poorly machined. They always hang up and cause a high idle. Dangerous really
A friend of mine used to solder a speedo cable to the mixture screws with some nuts soldered on the very end. It was easy to adjust but you always had the speedo cables hanging out. I guess you could just clip'em off when you have it setup.
Myself I always just keep moving the front to the back
Re: My Solution For The Rear Six Pack Carb Idle Screws! [Re: scatpacktom] #1081100
09/24/11 01:19 PM
09/24/11 01:19 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Bought one of the adjustable plates when they first came out,never had a problem and worked/works flawlessly.Same plate from same source today is not the quality as the first.
Re: My Solution For The Rear Six Pack Carb Idle Screws! [Re: 62maxwgn] #1081101
09/24/11 02:04 PM
09/24/11 02:04 PM
Yeah, not to mention that you have to swap all of your stuff over to those plates as well. You would think for the money that they would come ready-to-run
Re: My Solution For The Rear Six Pack Carb Idle Screws! [Re: 69sixpackbee] #1081102
09/24/11 02:08 PM
09/24/11 02:08 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Paid $115 when they first came out,production cost must have really gone up!
Re: My Solution For The Rear Six Pack Carb Idle Screws! [Re: 62maxwgn] #1081103
09/25/11 11:18 AM
09/25/11 11:18 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Very nice design. I went even one step easiers than that. I took the side metering screws that are in any old metering block off any 750 style carb & installed them in the base plate of my six pack carbs. These mixture screws are alittle longer in length & make the slotted end stick out of the base plate slightly so you can see what you are doing. I then un-bent an old wire coat hanger, straightened it out cut to about 24" long flattened & ground on end like a small screw driver & made a small handle on the other end to be able to twist it. Works great, took 5 mins to make & was all free.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
