Isky EZ Roll compared to Comp roller lifters #1080320
09/22/11 06:19 AM
09/22/11 06:19 AM
Texas
Steve Reynolds Offline OP
Texas
Our 440 now has Comp solid rollers lifters and they will need to be replaced or rebuilt this coming winter. This has been done many times. I am interested in the Isky EZ Roll & need to know what is good or bad about them. The Comp lifters are ok, but seem to require more maintenance & nickel & dime,(replace 5, rebuild the rest). Are the Isky any better & can they be just dropped in to replace the Comps. I would like to have opinions & real experiences.
Steve
Re: Isky EZ Roll compared to Comp roller lifters [Re: Steve Reynolds] #1080321
09/22/11 08:19 AM
09/22/11 08:19 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Only thing about changing lifter brands is that there is "No Standard" in push rod cup height. Chances are you will need diff push rods too.
I personally like the 829 Comp Lifters, never had trouble, and run 750-800 lbs open pressure.
I just check them on a regular basis, and replace them after 250-300 pass's.
I cant comment on the Isky lifters.
Re: Isky EZ Roll compared to Comp roller lifters [Re: Bob_Coomer] #1080322
09/22/11 09:23 AM
09/22/11 09:23 AM
Texas
Texas
It's not that we have had a lot of problems, I just keep hearing & seeing problems with the tiny roller bearings & it appears Isky has done away with these bearings & put a bushing in their place claiming 350% better. I suspected that the push rods would need to be replaced, but I was not sure about anything else like block work etc, also if the bearings are not there they can't fall out & make a total mess of things.
thanks for your reply & advice,
Steve
Re: Isky EZ Roll compared to Comp roller lifters [Re: Steve Reynolds] #1080323
09/22/11 10:44 AM
09/22/11 10:44 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have been very happy with my EZ rolls from Isky.
Re: Isky EZ Roll compared to Comp roller lifters [Re: Al_Alguire] #1080324
09/22/11 10:59 AM
09/22/11 10:59 AM
Texas
Texas
Al, have you ever used any other roller lifter, or had the maintenance issues with Isky such as replace 5 lifters & rebuild the rest every 200- 300 runs, or sooner. We have done this 2-3 times between each rebuild. Am I asking too much from any roller lifter?
Steve
Re: Isky EZ Roll compared to Comp roller lifters [Re: Steve Reynolds] #1080325
09/22/11 11:06 AM
09/22/11 11:06 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
The Isky's are higher quality and more expensive. The Comps are OK, I don't like the Mickey Mouse way the pushrod seat is retained in the lifter body. I have had some pull out when removing pushrods on an assembled engine. No fun fishing the seat out of the valley and hoping that the thing didn't drop through. I like the link bar design better as well.
MB
Re: Isky EZ Roll compared to Comp roller lifters [Re: Bob_Coomer] #1080326
09/22/11 11:29 AM
09/22/11 11:29 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Remember, the 829 is the older original Comp solid roller. The 829 relies on splash for oiling. Then they came out with the Endure-X that uses an EDM oil hole to provide oil to the roller. And finally their ultimate lifter called the Elite (98829-16), which oils both the roller and allows oiling through the pushrod. The elite also has a different body style to minimize lifter bore scuffing and they are made from a lighter alloy. But they cost $1000!
The Isky red zones are great lifters. Not as "high tech" as the Elites but probably better than the 829s.
And as long as we're spending big $ don't overlook the Crower lifters.
Re: Isky EZ Roll compared to Comp roller lifters [Re: Mopar_Rich] #1080327
09/22/11 12:22 PM
09/22/11 12:22 PM
Texas
Texas
My 2 biggest issues with Comp roller lifters are replace or rebuild 2-3 times between engine rebuilds & or if the roller bearings come apart & the bearings drop into the rotating assembly & create a total engine dissaster, these examples are what I would like to get away from.
thanks for all info & advice
Steve
Re: Isky EZ Roll compared to Comp roller lifters [Re: Steve Reynolds] #1080328
09/22/11 12:53 PM
09/22/11 12:53 PM
Dyno1 Offline
Dyno1  Offline
I replace the 829's after every season. The Isky stuff is expensive, but cheaper than replacing an entire engine. I sell them for $200.00 on Craigslist and put a fresh set in the spring. Dyno
Re: Isky EZ Roll compared to Comp roller lifters [Re: Steve Reynolds] #1080329
09/23/11 12:23 PM
09/23/11 12:23 PM
WI.
Scotts71chall Offline
WI.
I was just lookin at Cranes Ultra-Pro #66542-16
Any one like them for street/strip? $755
Crane Ultra-Pro™ roller lifters are the ultimate in state-of-the-art, drop-in design premium
quality roller lifters! Empirical design and development techniques have been used
to eliminate any distortion effects of residual stresses resulting from the heat treat process.
Ultra-Pro™ roller lifters feature maximized strength; especially in the axle support
struts. This insures geometrically perfect tracking of the roller wheel. Additionally,
super-premium wheels, axles and bearings made from the finest grades of alloy steels
are used to conquer even the most violent cam lobe profiles currently designed or
anticipated for the next several years! These lifters represent the best combination of
lightweight, ultimate strength and reliability. They should be used in all drag race
applications with spring seat pressures in excess of 300 lbs., and open pressures over
800 lbs. In addition, they should be used in any short-track circle or endurance racing
application where valve spring seat pressures exceed 250 lbs., and open pressures
exceed 700 lbs. Use Crane Cams Ultra-Pro™ series lifters when absolute durability is necessary.
With Crane Cams Ultra-Pro™ roller lifters, engine builders can now be sure that they’re using the absolute finest available,
professional quality roller lifters for high-stress race engine applications. Count on Crane Cams to give you a full selection
of performance products with the best performance for the buck and peace of mind for you.
Re: Isky EZ Roll compared to Comp roller lifters [Re: Scotts71chall] #1080330
09/23/11 01:35 PM
09/23/11 01:35 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
The Crane 66542-16 are great lifters. I used the 66550-16 in my HEMI book because I wanted pushrod oiling. The body design for the Ultra-Pro lifters is such that they do not require bushed lifter bores. They look just like the Comp Elites but for $250 less.
Re: Isky EZ Roll compared to Comp roller lifters [Re: Mopar_Rich] #1080331
09/23/11 03:47 PM
09/23/11 03:47 PM
Kansas City Metro
mbogina Offline
mbogina  Offline
Kansas City Metro
I recently purchased a set of the Comp Cams Elite and I am very unhappy with them, they failed on the 5th dyno pass, link bar broke in half on one pair, killed the pair and the 55mm cam. Link bar on every remaining pair is bent. Total waste of $1000. We got away from the 829's a few years ago, the needles were always failing. For the valvetrain weight and springs of our hemi SS stuff, only the Jesel keyway and Jesel dogbone have lived, 5 years+ on same set, no failures. Comp 829's wouldn't last 20 runs.
Be a Rebel- Break the Laws of Physics!
Re: Isky EZ Roll compared to Comp roller lifters [Re: mbogina] #1080332
09/24/11 02:44 AM
09/24/11 02:44 AM
NEW JERSEY
BIGSPEED Offline
BIGSPEED  Offline
NEW JERSEY
We use Isky EZrolls in most of our engines,The elimination of the needle bearings is like a cure for cancer,needle bearing failure can cause thousands of dollars in damage,our customers now have money for upgrades instead of repairs.Bill C.
Ceralli Racing Engines & Checkered Flag Machine Racing engines , CNC porting & induction development http://www.checkeredflagmachine.net/
Re: Isky EZ Roll compared to Comp roller lifters [Re: BIGSPEED] #1080333
09/24/11 03:49 AM
09/24/11 03:49 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have in the past used the 829's. Occasionally we build an engine for someone who insists on using them, usually a budget deal. We let them know that they will need to at the very least be sent in to be checked/rebuilt every year. Also advise them to carry spares
My B1 uses EZ rolls. I have used the std red zones as well with good results.
