Transmission hump numbers #1073502
09/11/11 10:50 PM
09/11/11 10:50 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
I picked up a nice used transmission hump this weekend, it has some numbers stamped in the top, SS27 and a 1, is it an OEM or aftermarket? Is it a date stamp? I think its for a B-body. Thanks Tim
Re: Transmission hump numbers [Re: astjp2] #1073503
09/11/11 11:04 PM
09/11/11 11:04 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
On OE sheetmetal the SS stamping stands for Sterling Stampworks (or something like that?) It was one of Chryslers sheetmetal stamping locations.
I do not know if any of those markings are being replicated on the new parts?
Re: Transmission hump numbers [Re: astjp2] #1073504
09/11/11 11:05 PM
09/11/11 11:05 PM
New York, USA
Chargerfan68 Offline
New York, USA
All I can tell you is that the stamping is from the Factory Sheetmetal Plant. If you look at (probably) every piece of sheetmetal on our cars, each one has a stamping. Most on my car start with SS. So, I would say it is OEM, as I have not seen any aftermarket stuff with these stampings. Not even AMD sheetmetal has these stampings.
Maybe licensing reasons. Can't help you on whether it is for a B-body. Check the fit on the B body floorpan. It should fit extremely well to the profile of the floorpan.
Good Luck,
Greg.
