no oil on top end 383 #1072432
09/09/11 11:34 PM
09/09/11 11:34 PM
WALLINGFORD, CT. 06492
BP68RR383 Offline OP
had my 383 h.p. motor rebuilt ran it about 30 min. bent a push rod no oil on the top end why???????
Re: no oil on top end 383 [Re: BP68RR383] #1072433
09/09/11 11:44 PM
09/09/11 11:44 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Most likely cause is an incorrectly installed #4 cam bearing..
Re: no oil on top end 383 [Re: 1_WILD_RT] #1072434
09/10/11 12:08 AM
09/10/11 12:08 AM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
i had the same problem,cam bearing installed wrong and only one side got oiled,my fix was to (wich i dont recomend was to get a long drill bit and pull the cam and drill it and flush but if you are going to pull the cam might as well do it right
Re: no oil on top end 383 [Re: BP68RR383] #1072435
09/10/11 12:41 AM
09/10/11 12:41 AM
pull the dist/inter gear/shaft & drill prime it CCW & see if the pass side head oils w the marks at TDC #6 then hand turn it 1&1/4 turns (rotor at #8) & see if the DR side head oils
Re: no oil on top end 383 [Re: BP68RR383] #1072436
09/10/11 01:01 AM
09/10/11 01:01 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
30 min ...no oil ....you probably hurt many parts of the valve train ...especially the springs and valve stems.
Re: no oil on top end 383 [Re: dOoC] #1072437
09/12/11 01:03 PM
09/12/11 01:03 PM
San Gabriel, CA 91775
rexus31 Offline
rexus31  Offline
Did you rotate the crank while priming?
2007 Dodge Charger R/T, Road and Track Performance Group, Steel Blue 1965 Chrysler 300 Convertible, 383 4V, 727TF, Factory Air, Spanish Red 1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red "What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield
Re: no oil on top end 383 [Re: rexus31] #1072438
09/12/11 01:17 PM
09/12/11 01:17 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I would sure think that the engine was rotating while it was running for 30 minutes.
Re: no oil on top end 383 [Re: MoparforLife] #1072439
09/12/11 01:18 PM
09/12/11 01:18 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It has been found that the cam was also not drilled properly on the #4 journal.
Re: no oil on top end 383 [Re: JohnRR] #1072440
09/12/11 02:06 PM
09/12/11 02:06 PM
Upper Midwest
Upper Midwest
Makes for a mess of a job because of a factory screw up.
Re: no oil on top end 383 [Re: BP68RR383] #1072441
09/12/11 02:12 PM
09/12/11 02:12 PM
okla.
O
okie Offline
okie  Offline
O
okla.
You could get you some hollow push rods and use them for a while untill you get a chance to tear it down. I know every one says it won't work but I've been running mine like this for a year. It is working all right untill I decide to tear it down and replace the cam bearing.
Re: no oil on top end 383 [Re: okie] #1072442
09/12/11 04:02 PM
09/12/11 04:02 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
How is this getting oil to the ROCKER SHAFTS ????
Re: no oil on top end 383 [Re: JohnRR] #1072443
09/12/11 04:22 PM
09/12/11 04:22 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Oh, I think he's talking about oiling through pushrods.....
Re: no oil on top end 383 [Re: buildanother] #1072444
09/12/11 04:27 PM
09/12/11 04:27 PM
Upper Midwest
Upper Midwest
Which also means using AMC/Mopar compatible aftermarket lifters with the oil feed in the plunger.
Re: no oil on top end 383 [Re: buildanother] #1072445
09/12/11 05:03 PM
09/12/11 05:03 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes he is , but how does the oil get into the rocker shafts ?
Re: no oil on top end 383 [Re: MoparforLife] #1072446
09/12/11 05:16 PM
09/12/11 05:16 PM
okla.
O
okie Offline
okie  Offline
O
okla.
I'm just using the lifters that came with my Comp cam. Nearly all the lifters have oil holes in them. I'm just running the stock rockers and they oil very good.
Re: no oil on top end 383 [Re: okie] #1072447
09/12/11 05:33 PM
09/12/11 05:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
How ??? There is no path for the oil to go from the pushrod cup in the rocker to the underside of the rocker.
Re: no oil on top end 383 [Re: JohnRR] #1072448
09/12/11 06:29 PM
09/12/11 06:29 PM
Upper Midwest
Upper Midwest
Stock stamped rockers have a weep hole in the push rod cup.
Re: no oil on top end 383 [Re: MoparforLife] #1072449
09/12/11 07:37 PM
09/12/11 07:37 PM
okla.
O
okie Offline
okie  Offline
O
okla.
They do oil good thru the hole and it also blows it all inside the cover. Just drove it about 200 miles this week end. I got my push rods from Smith Bros. and they are good. I will fix it one of these days when I have to tear the motor down. I had worked on it for so long I didn't want to tear it down as soon as I got it going. Another lesson learned never trust your machine shop always check things. Ronnie
Re: no oil on top end 383 [Re: BP68RR383] #1072450
09/12/11 09:16 PM
09/12/11 09:16 PM
Thanks guys for all your HELP. Yes i did rotate the crank while priming,I was told it also could be the rocker shafts were put on wrong?????
Re: no oil on top end 383 [Re: BP68RR383] #1072451
09/12/11 09:53 PM
09/12/11 09:53 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That makes no sense , even if you put the shafts on upside down you would still get oil. either the cam bearing is in wrong or the holes in the cam are not there/complete.
