Re: no oil on top end 383
[Re: BP68RR383]
#1072433
09/09/11 11:44 PM
09/09/11 11:44 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Most likely cause is an incorrectly installed #4 cam bearing..
[Re: 1_WILD_RT]
#1072434
09/10/11 12:08 AM
09/10/11 12:08 AM
Posts: 1,107 Spring Valley ,Ca.
moparsquid
Spring Valley ,Ca.
i had the same problem,cam bearing installed wrong and only one side got oiled,my fix was to (wich i dont recomend was to get a long drill bit and pull the cam and drill it and flush but if you are going to pull the cam might as well do it right
[Re: BP68RR383]
#1072435
09/10/11 12:41 AM
09/10/11 12:41 AM
RapidRobert
pull the dist/inter gear/shaft & drill prime it CCW & see if the pass side head oils w the marks at TDC #6 then hand turn it 1&1/4 turns (rotor at #8) & see if the DR side head oils
[Re: BP68RR383]
#1072436
09/10/11 01:01 AM
09/10/11 01:01 AM
Posts: 30,460 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
had my 383 h.p. motor rebuilt ran it about 30 min. bent a push rod no oil on the top end why???????
30 min ...no oil ....you probably hurt many parts of the valve train ...especially the springs and valve stems.
[Re: dOc !]
#1072437
09/12/11 01:03 PM
09/12/11 01:03 PM
Posts: 366 San Gabriel, CA 91775
rexus31
Did you rotate the crank while priming?
2007 Dodge Charger R/T, Road and Track Performance Group, Steel Blue
1965 Chrysler 300 Convertible, 383 4V, 727TF, Factory Air, Spanish Red
1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red
"What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield
[Re: rexus31]
#1072438
09/12/11 01:17 PM
09/12/11 01:17 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
I would sure think that the engine was rotating while it was running for 30 minutes.
[Re: MoparforLife]
#1072439
09/12/11 01:18 PM
09/12/11 01:18 PM
Posts: 75,074 U.S.S.A.
JohnRR
U.S.S.A.
It has been found that the cam was also not drilled properly on the #4 journal.
[Re: JohnRR]
#1072440
09/12/11 02:06 PM
09/12/11 02:06 PM
MoparforLife
Upper Midwest
Makes for a mess of a job because of a factory screw up.
[Re: BP68RR383]
#1072441
09/12/11 02:12 PM
09/12/11 02:12 PM
Posts: 1,222 okla.
okie
okla.
You could get you some hollow push rods and use them for a while untill you get a chance to tear it down. I know every one says it won't work but I've been running mine like this for a year. It is working all right untill I decide to tear it down and replace the cam bearing.
[Re: okie]
#1072442
09/12/11 04:02 PM
09/12/11 04:02 PM
JohnRR
U.S.S.A.
How is this getting oil to the ROCKER SHAFTS ????
[Re: buildanother]
#1072445
09/12/11 05:03 PM
09/12/11 05:03 PM
JohnRR
U.S.S.A.
Oh, I think he's talking about oiling through pushrods.....
Yes he is , but how does the oil get into the rocker shafts ?
[Re: okie]
#1072447
09/12/11 05:33 PM
09/12/11 05:33 PM
JohnRR
U.S.S.A.
I'm just using the lifters that came with my Comp cam. Nearly all the lifters have oil holes in them. I'm just running the stock rockers and they oil very good.
How ??? There is no path for the oil to go from the pushrod cup in the rocker to the underside of the rocker.
[Re: BP68RR383]
#1072451
09/12/11 09:53 PM
09/12/11 09:53 PM
JohnRR
U.S.S.A.
Thanks guys for all your HELP. Yes i did rotate the crank while priming,I was told it also could be the rocker shafts were put on wrong?????
That makes no sense , even if you put the shafts on upside down you would still get oil. either the cam bearing is in wrong or the holes in the cam are not there/complete.
