motor home 440, probably asked a thousand times #1072001
09/09/11 12:52 PM
09/09/11 12:52 PM
Unfortunately back in New York
N
Nukechargerboy Offline OP
N
A friend of mine is trying to give me a 440 out of a motor home. He says it was rebuilt 15 years ago and it's sitting in his mothers driveway. Are the heads different on these 440's ? I'm getting the itch to go grab it.
Re: motor home 440, probably asked a thousand times [Re: Nukechargerboy] #1072002
09/09/11 12:55 PM
09/09/11 12:55 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
most likley 452 heads
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: motor home 440, probably asked a thousand times [Re: Nukechargerboy] #1072003
09/09/11 12:56 PM
09/09/11 12:56 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
GIVE YOU IT ? ... what are you waiting for ? ... REbuilt or not. But don't count on the parts being much in the HP department. The heads ? ... not-so-much either.
Re: motor home 440, probably asked a thousand times [Re: dOoC] #1072004
09/09/11 01:03 PM
09/09/11 01:03 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
the heads on the 413 are different and they use a special exhaust manifold---the heads are way bigger than the old 452---i suspect the 440 is the same as the 413---but the motor is still worth the trouble---bob
Re: motor home 440, probably asked a thousand times [Re: savoy64] #1072005
09/09/11 01:09 PM
09/09/11 01:09 PM
N
N
I'll go get it as soon as I can. It's not really give, 2 benjamins and a case of beer. Better than Carlisle and it is close to home.
Re: motor home 440, probably asked a thousand times [Re: Nukechargerboy] #1072006
09/09/11 01:52 PM
09/09/11 01:52 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I got two motor home 440's hear both are regular cast crank 440's with 452 heads (I got $10 iron weight for each set) one standard 727 one had the short output with u joint converted it to regular output and it is in my buddy's Henry J gasser!
since bare blocks are worth $200 to $500 and tranny $75 to $200 grab it plus they work fine in mild street as is!
