Re: a wiped cam lobe or lifter colapsed ?
[Re: 70Cuda383]
#1071261
09/08/11 11:15 AM
09/08/11 11:15 AM
Posts: 183 Eden, Texas
Strawdawg
Eden, Texas
I am sure it is a typo as the break in rpm would be more like 2200 and not 1200.
You can pull the rocker shaft and reach down with a good magnet and pull the lifter out without pulling the intake.
Altho, I have done this on a bb, so in second thought, I don't know if this works on a sb.....
Steve
[Re: mikepar]
#1071265
09/09/11 12:00 AM
09/09/11 12:00 AM
Posts: 4,450 Michigan
MarkZ
Worthy
Worthy
J heads? This was about five years ago, but I remember not being able to fish a lifter out with J heads when I suspected a flat lobe.
[Re: mikepar]
#1071266
09/09/11 08:12 AM
09/09/11 08:12 AM
Posts: 327 pittsburgh,Pa.
mikepar
pittsburgh,Pa.
yes I did say 1200 rpm's in a typo ,I meant 2200,and some of these tips you guys gave are great ideas,and ......I'll let you know. THANKS BUNCHES GUYS MIKE
[Re: mikepar]
#1071269
09/11/11 08:40 PM
09/11/11 08:40 PM
Strawdawg
Eden, Texas
Hopefully not...but, you need to inspect the bearings and get the debris out of the oil passages and the rest of the engine to be safe.
Steve
[Re: mikepar]
#1071270
09/11/11 08:58 PM
09/11/11 08:58 PM
Posts: 75,088 A Banana Republic near you.
JohnRR
so if I wipped the cam, then now the whole engine needs rebuilt, right? still havent found the time to look at it
I needs to be torn down and cleaned , new oil pump more than likely and possibly bearings , cylinder and pistons under the wipe lobed need to be looked at .
