a wiped cam lobe or lifter colapsed ? #1071258
09/08/11 08:35 AM
09/08/11 08:35 AM
pittsburgh,Pa.
mikepar Offline OP
mikepar  Offline OP
pittsburgh,Pa.
without removing the intake..I did take off the valve covers and discovered one of my exhaust valves was getting little if any movement
from the lifter. With the engine (360) running, when I pushed back on the rocker arm toward the push rod it was jumping some.With the engine OFF the push rod would move towards the lifter and spring back when let go.Im guessing/hoping that the lifter collapsed.This was on a fairly new Lunaty Voodoo cam and lifter installation less than 50 miles. I hope I broke it in right and proper,but had no tack on it to get to my 1200 rpms during break in.Removing the intake will tell the tale when I look at the lobe of the cam.But just wanted to see what the experts here have to say first.I'm afraid to look. LOL MAN that was making a loud popping through the carb
Re: a wiped cam lobe or lifter colapsed ? [Re: mikepar] #1071259
09/08/11 09:18 AM
09/08/11 09:18 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
See if you can get a long thin screwdriver etc and see if you can rest it on lifter body while someone turns crank slowly for you to see if the lifter is still lifting as much as it should(to rule out cam lobe). If it's popping through carb at idle, I would bet a lobe is wiped.
Re: a wiped cam lobe or lifter colapsed ? [Re: buildanother] #1071260
09/08/11 09:37 AM
09/08/11 09:37 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
a collapsed lifter that isn't opening the exhaust valve fully, would act the same as a fully functional lifter on a wiped lobe that isn't opening the valve fully.
could be either one at this point, but if you pushed down on the pushrod to keep tension on it, and could feel the lobe of the cam moving the lifter up and down, the cam just might be ok.
**Photobucket sucks**
Re: a wiped cam lobe or lifter colapsed ? [Re: 70Cuda383] #1071261
09/08/11 11:15 AM
09/08/11 11:15 AM
Eden, Texas
Strawdawg Offline
Strawdawg  Offline
Eden, Texas
I am sure it is a typo as the break in rpm would be more like 2200 and not 1200.
You can pull the rocker shaft and reach down with a good magnet and pull the lifter out without pulling the intake.
Altho, I have done this on a bb, so in second thought, I don't know if this works on a sb.....
Steve
Re: a wiped cam lobe or lifter colapsed ? [Re: Strawdawg] #1071262
09/08/11 12:04 PM
09/08/11 12:04 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Just ran into a similar deal on a buddy's boat running a Ford 351W. Not a fresh build, but he'd killed the head gaskets and it had water in it. Found the rear rockers were REALLY loose, no resistance from the hydraulic lifters. Cam looked OK. Replaced rear lifters and it's back up & running.
Lunati says 1200 RPM? I've always run 2000-2500 for cam break-in to get plenty of oil splash, and soaked hyd lifters in oil before installation.
Re: a wiped cam lobe or lifter colapsed ? [Re: topside] #1071263
09/08/11 01:37 PM
09/08/11 01:37 PM
fury4speed Offline
fury4speed  Offline
Cut open the oil filter and if there are a bunch of metal in the filter , if there is fine metal particles it is probaly the cam lobe/s going flat.
Break in the cam at least 2000 RPM for 30 min and using a good oil / break in lube additive.
Re: a wiped cam lobe or lifter colapsed ? [Re: Strawdawg] #1071264
09/08/11 01:54 PM
09/08/11 01:54 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Years ago I had a 1976 dodge van with a 318 that I used for a tow vehicle. I needed more power so I built a 360 with a ld4b intake, 340 heads and a hydraulic cam. On the way to Ocean City, MD. it collapsed a couple of lifters. Luckily I had a few hand tools and a long magnet and changed them out in the hotel parking lot. Some of the slots in the heads were big enough to remove and replace the lifters without removing the intake. Took me about 1 1/2 hours start to finish working through the van doghouse. If you have the valve cover off see if a lifter will fit through the oil return slot and if so its not a bad job. If its the cam that's another story.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: a wiped cam lobe or lifter colapsed ? [Re: mikepar] #1071265
09/09/11 12:00 AM
09/09/11 12:00 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
J heads? This was about five years ago, but I remember not being able to fish a lifter out with J heads when I suspected a flat lobe.
Re: a wiped cam lobe or lifter colapsed ? [Re: mikepar] #1071266
09/09/11 08:12 AM
09/09/11 08:12 AM
pittsburgh,Pa.
mikepar Offline OP
mikepar  Offline OP
pittsburgh,Pa.
yes I did say 1200 rpm's in a typo ,I meant 2200,and some of these tips you guys gave are great ideas,and ......I'll let you know.
THANKS BUNCHES GUYS
MIKE
Re: a wiped cam lobe or lifter colapsed ? [Re: mikepar] #1071267
09/09/11 11:55 AM
09/09/11 11:55 AM
Eastern,NC
68GTS383 Offline
68GTS383  Offline
Eastern,NC
If you follow fury4speed's suggestion and find metal in the oil filter then you will need to tear the engine back down.You will probably find metal in your main,rod or cam bearings. Been there done that! Good luck
Re: a wiped cam lobe or lifter colapsed ? [Re: 68GTS383] #1071268
09/11/11 07:52 PM
09/11/11 07:52 PM
pittsburgh,Pa.
mikepar Offline OP
mikepar  Offline OP
pittsburgh,Pa.
so if I wipped the cam, then now the whole engine needs rebuilt, right?
still havent found the time to look at it
Re: a wiped cam lobe or lifter colapsed ? [Re: mikepar] #1071269
09/11/11 08:40 PM
09/11/11 08:40 PM
Eden, Texas
Strawdawg Offline
Strawdawg  Offline
Eden, Texas
Hopefully not...but, you need to inspect the bearings and get the debris out of the oil passages and the rest of the engine to be safe.
Steve
Re: a wiped cam lobe or lifter colapsed ? [Re: mikepar] #1071270
09/11/11 08:58 PM
09/11/11 08:58 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I needs to be torn down and cleaned , new oil pump more than likely and possibly bearings , cylinder and pistons under the wipe lobed need to be looked at .
Re: a wiped cam lobe or lifter colapsed ? [Re: JohnRR] #1071271
09/12/11 10:36 AM
09/12/11 10:36 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
fish the lifter out and look at the bottom of the lifter, you will know then
