Re: BEA/PGClassic 4 speed rods.
[Re: 440newport]
#1070966
09/07/11 04:39 PM
09/07/11 04:39 PM
Posts: 4,285 Ohio
64dodge572
Ohio
Your having problems because the rods are not made correctly. Wait til you get the trans in the car and try to fit the rods around the torsion bar crossmember. The rods should look like this:
Dan
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: 64dodge572]
#1070967
09/07/11 04:40 PM
09/07/11 04:40 PM
Posts: 4,285 Ohio
64dodge572
Ohio
Another pic from the rear.
Dan
[Re: 64dodge572]
#1070970
09/07/11 04:46 PM
09/07/11 04:46 PM
Posts: 4,588 St. John's Newfoundland
440newport
Dan
I bought most of the rest of the parts I needed for my 4 speed swap from you guys a few weeks ago. I bought the OE style clip and washer set because I didn't like the little cotter pins these came with. In fact when I first bought these rods and saw the cheesy nylon bushings on the ends I wished I'd just bought the real deals from you guys in the first place.
[Re: 440newport]
#1070971
09/07/11 04:51 PM
09/07/11 04:51 PM
Posts: 4,285 Ohio
64dodge572
Ohio
I get lots of calls about their linkage (clutch and shifter), not sure what they used for samples. Dan
[Re: 440newport]
#1070973
09/07/11 05:04 PM
09/07/11 05:04 PM
Posts: 75,015 U.S.S.A.
JohnRR
U.S.S.A.
Do you think the 1-2 and 3-4 rods will have interference problems too? They seem similar to the original style.
Looks like reverse wants to go directly through the crossmember though.
Part of your problem is that shift box mount , the box is tipped a little too far forward , just pony up for the correct rods tightwad .
[Re: JohnRR]
#1070974
09/07/11 05:13 PM
09/07/11 05:13 PM
440newport
The shifter mount is brand new A body billet piece from Brewers. It might look tipped because it's in reverse in the pic. I agree I was being a tightwad on the rods...trying to save $40 is going to cost $130.
[Re: 440newport]
#1070975
09/07/11 05:16 PM
09/07/11 05:16 PM
Posts: 4,285 Ohio
64dodge572
Ohio
I would give them a call and see if they will take them back. I believe they have for others in the past. Dan
[Re: northcoastmopar]
#1070978
09/07/11 09:28 PM
09/07/11 09:28 PM
JohnRR
U.S.S.A.
Now I just need to get one of those cool rt angle alignment tools shown in the pic.
It's a 1/4" diameter piece of round stock , A long dowel or drill bit works in a pinch.
[Re: JohnRR]
#1070979
09/07/11 09:51 PM
09/07/11 09:51 PM
Posts: 4,366 Cleveland, Ohio
northcoastmopar
Cleveland, Ohio
I use a shortened drill bit, I just sometimes have trouble finding in my messy toolbox. That white tool would be easy to spot.
#1070980
09/08/11 10:04 AM
09/08/11 10:04 AM
JohnRR
U.S.S.A.
I guess you can try to buy one then , or make one , it's just a piece of plastic rod bent in a 90
[Re: 64dodge572]
#1070981
09/08/11 04:50 PM
09/08/11 04:50 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
Dan
the guys you should of got your rods from nailed it. Also if you can get the rods to work...They always need adjusting as they were heat treated originally and these cheap expensive repo's are not and easily bend from use....
