Rear axle seal installation Qs #1070182
09/06/11 08:34 AM
09/06/11 08:34 AM
germany
440sat72 Offline OP
440sat72  Offline OP
germany
Hi,
i've run into problems when installing my rear axles seals (inner). They seem to be too big to fit into the axle ... or am i doing something wrong? How do you install your rear axles seals?
Thanks for your help!
Michail
Re: Rear axle seal installation Qs [Re: 440sat72] #1070183
09/06/11 09:16 AM
09/06/11 09:16 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
You have to drive them in and must be driven in to the lip stop machined into the housing. They also must be driven in square with the housing or they will leak. Hear is what Iuse. It is made for the job.
Re: Rear axle seal installation Qs [Re: 440sat72] #1070184
09/06/11 09:52 AM
09/06/11 09:52 AM
for 8&3/4's there's an app that's a bit 2 big, they wont even start to go in the housing. Been awhile/dont have #'s 4 you
Re: Rear axle seal installation Qs [Re: RapidRobert] #1070185
09/06/11 10:53 AM
09/06/11 10:53 AM
germany
440sat72 Offline OP
440sat72  Offline OP
germany
i dont understand ... what's an app?
sorry, language barrier ...
Re: Rear axle seal installation Qs [Re: 440sat72] #1070186
09/06/11 11:14 AM
09/06/11 11:14 AM
scratchnfotraction Offline
APP = application = type of vehical
Re: Rear axle seal installation Qs [Re: scratchnfotraction] #1070187
09/06/11 12:31 PM
09/06/11 12:31 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
for most 8 3/4 applications for the inner seals are #2404215 same as 2881185 mopar or 8695S aftermarket. what is the number off the old seal?
Re: Rear axle seal installation Qs [Re: mopars4ever] #1070188
09/06/11 03:21 PM
09/06/11 03:21 PM
Yeah you'd think the inner seal # would b the same 4 all (8&3/4) so I may have been handed one 4 a diff app (been several years ago) but the OD was too big (close though) to even get started
Re: Rear axle seal installation Qs [Re: RapidRobert] #1070189
09/07/11 05:02 AM
09/07/11 05:02 AM
germany
440sat72 Offline OP
440sat72  Offline OP
germany
I guess i ran into a pair of those ... got another set yesterday and they went in with no problems!
thanks for your help anyway!
Re: Rear axle seal installation Qs [Re: 440sat72] #1070190
09/07/11 11:47 AM
09/07/11 11:47 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Cheap easy installer.Get a piece of PCV thats close to the seal size.Then just drive them in with it.Cost a few bucks and they are square and even in the housing.Rocky
Chrysler Firepower
Re: Rear axle seal installation Qs [Re: therocks] #1070191
09/09/11 01:04 PM
09/09/11 01:04 PM
germany
440sat72 Offline OP
440sat72  Offline OP
germany
now it's all settled. got a second pair of seals that went in with no problems - seems like the first pair i had wre just too big.
found i nice way to drive them in btw.:
take one of the old seals and cut it in one place with an angle grinder so that it can compress a little bit. then take a piece of 2.5" pipe and slide the old and cut bearing over the pipe - now you have a perfect tool to drive in the new seals!
Re: Rear axle seal installation Qs [Re: 440sat72] #1070192
09/09/11 02:23 PM
09/09/11 02:23 PM
BDW Offline
BDW  Offline
Got a pic of that? Not following what you did.
Re: Rear axle seal installation Qs [Re: BDW] #1070193
09/09/11 03:46 PM
09/09/11 03:46 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
i believe he used the old seal on the end of a pipe as the driver for the new seal, just cut so it is able to be compressed a bit.
