Re: Broke a stock axle @ the track; happen to anybody else?
[Re: olwhite64]
#1066294
08/31/11 12:30 AM
08/31/11 12:30 AM
Posts: 52,972 Romeo MI
MR_P_BODY
They would not have broke with a suregrip? I am seriously asking....
They ALL twist outside of the spool(the spool holds the splines straight).... I broke a stock axle 35 years ago... I always buy aftermarket for any car with any type of slicks... my currant axles have about 1 whole spline of twist and they've stayed there.... by the way... paint a white line down the whole length of the new axles when you put the new ones in.... you will learn ALOT from that line
[Re: Cab_Burge]
#1066297
08/31/11 01:49 AM
08/31/11 01:49 AM
Posts: 4,027 Dearborn Hts, MI
Sledge_57
Dearborn Hts, MI
Short lifespan? That was what, a 45 year old axle you were abusing?
Anyway I did the same thing with a locker, I went to Strange after mine broke...
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
[Re: Mr.Yuck]
#1066300
08/31/11 09:34 AM
08/31/11 09:34 AM
Posts: 75,094 A Banana Republic near you.
JohnRR
ouch 12.60? Now I know I need to swap mine out ASAP. I have a set from DrDiff sitting next to the car. FWIW I ran 12.0's with stock rear/axles for and entire year w/ no problems 1.65 60 foot in a 3850lb car. This one has had only a few runs and 1.60 60 foot.
When is the last time you looked at the splines on either car?
[Re: JohnRR]
#1066302
08/31/11 09:46 AM
08/31/11 09:46 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
never but I'll be looking at these soon as they will be swapped out before the next "outting" as I plan on making some 100% all out passes.
[Re: aquamist60]
#1066304
08/31/11 10:47 AM
08/31/11 10:47 AM
Posts: 2,103 East Coast, NJ
fig426
East Coast, NJ
A friend of mine broke his in his 12.50 AAR.
Chris from New Jersey
[Re: olwhite64]
#1066306
08/31/11 12:20 PM
08/31/11 12:20 PM
MR_P_BODY
Thanks for the tip...I'm betting there is no such thing as a cheap Dana 60...
Go to the bone yard and see what you can find... you dont want the HEAVY DUTY one.... the tubes are THICK
[Re: 440Jim]
#1066308
08/31/11 09:42 PM
08/31/11 09:42 PM
Posts: 9,882 MI, usa
dvw
MI, usa
I ran resplined axles with a sure grip for over 15 years 11.60@3800lbs. They had 1 spline of twist when replaced. I also ran 12.50@3750lbs with a stick for about 100 passes with the same amount of twist. Both on slicks. Doug
