Broke a stock axle @ the track; happen to anybody else? #1066291
08/31/11 12:02 AM
08/31/11 12:02 AM
High Plains of South Dakota
O
olwhite64 Offline OP
O
I suppose it should seem obvious to me that it would eventually happen, but I thought I would have to be running a lot faster than 12.60's. I have never weighed the car, but I would guess it would probably weigh all of 3800 lbs. No transbrake, 3500 stall, 29.5 X 10.5 slicks, and I know I have less than 70 passes total on the car. It does have a spool in the 8 3/4 but I've never run it on the street; it been on the track only since I put it together. The left axle, (the one that didn't break) was twisted in the splines as well. Assuming the car led a pedestrian lifestyle before I got it, (that's what I'm told) I am just surprised that they had such a short lifespan. I have lots of friend that have been running stock axles (in faster cars) for years with no problems. Fwiw they twisted just out side of the spool.
Re: Broke a stock axle @ the track; happen to anybody else? [Re: olwhite64] #1066292
08/31/11 12:07 AM
08/31/11 12:07 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Stock axles and a spool are a no no and now you know why.
Re: Broke a stock axle @ the track; happen to anybody else? [Re: scatpacktom] #1066293
08/31/11 12:11 AM
08/31/11 12:11 AM
O
O
They would not have broke with a suregrip? I am seriously asking....
Re: Broke a stock axle @ the track; happen to anybody else? [Re: olwhite64] #1066294
08/31/11 12:30 AM
08/31/11 12:30 AM
MR_P_BODY Offline
MR_P_BODY  Offline
They ALL twist outside of the spool(the spool holds
the splines straight).... I broke a stock axle 35 years
ago... I always buy aftermarket for any car with any
type of slicks... my currant axles have about 1 whole
spline of twist and they've stayed there.... by the
way... paint a white line down the whole length of
the new axles when you put the new ones in.... you
will learn ALOT from that line
Re: Broke a stock axle @ the track; happen to anybody else? [Re: MR_P_BODY] #1066295
08/31/11 12:38 AM
08/31/11 12:38 AM
O
O
Thanks for the tip...I'm betting there is no such thing as a cheap Dana 60...
Re: Broke a stock axle @ the track; happen to anybody else? [Re: olwhite64] #1066296
08/31/11 01:40 AM
08/31/11 01:40 AM
It sounds like the axles got swapped from one side to the other, usually the left axle breaks first I have broken two stock 8 3/4 axles with posi, none since I bought Strange race axles. I also switch to 35 splines with the new axles and spools I now run a Dana 60 with the same 35 spline race axles as I started with 6 years ago in the 8 3/4
Re: Broke a stock axle @ the track; happen to anybody else? [Re: Cab_Burge] #1066297
08/31/11 01:49 AM
08/31/11 01:49 AM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
Short lifespan? That was what, a 45 year old axle you were abusing?
Anyway I did the same thing with a locker, I went to Strange after mine broke...
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: Broke a stock axle @ the track; happen to anybody else? [Re: Sledge_57] #1066298
08/31/11 02:32 AM
08/31/11 02:32 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Broke an axle in my '66 Charger. 4150lbs. with me in it. Drag radials 4.30s with locker. Pretty exciting ride for a couple seconds.
Re: Broke a stock axle @ the track; happen to anybody else? [Re: Cab_Burge] #1066299
08/31/11 09:18 AM
08/31/11 09:18 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
ouch 12.60? Now I know I need to swap mine out ASAP. I have a set from DrDiff sitting next to the car. FWIW I ran 12.0's with stock rear/axles for and entire year w/ no problems 1.65 60 foot in a 3850lb car. This one has had only a few runs and 1.60 60 foot.
Coming soon!!!!
Re: Broke a stock axle @ the track; happen to anybody else? [Re: Mr.Yuck] #1066300
08/31/11 09:34 AM
08/31/11 09:34 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
When is the last time you looked at the splines on either car?
Re: Broke a stock axle @ the track; happen to anybody else? [Re: olwhite64] #1066301
08/31/11 09:35 AM
08/31/11 09:35 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No , they would break with a suregrip also.
Re: Broke a stock axle @ the track; happen to anybody else? [Re: JohnRR] #1066302
08/31/11 09:46 AM
08/31/11 09:46 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
never but I'll be looking at these soon as they will be swapped out before the next "outting" as I plan on making some 100% all out passes.
Re: Broke a stock axle @ the track; happen to anybody else? [Re: Mr.Yuck] #1066303
08/31/11 10:29 AM
08/31/11 10:29 AM
Ohio
aquamist60 Offline
aquamist60  Offline
Ohio
I checked mine when it was running low 13's on street tires & a 4.10 gear. Saw they were just starting to twist after 1 1/2 years racing it & street duty. It was an E-body 8 3/4 rear narrowed. Put aftermarket with a sure grip & finally a spool.
IIRC in the NHRA rule book it says aftermarket axles required with a spool.
Re: Broke a stock axle @ the track; happen to anybody else? [Re: aquamist60] #1066304
08/31/11 10:47 AM
08/31/11 10:47 AM
East Coast, NJ
fig426 Offline
fig426  Offline
East Coast, NJ
A friend of mine broke his in his 12.50 AAR.
Chris from New Jersey
Re: Broke a stock axle @ the track; happen to anybody else? [Re: fig426] #1066305
08/31/11 10:56 AM
08/31/11 10:56 AM
sweden
sshemi Offline
sshemi  Offline
sweden
ofcourse they give up faster with a spool.
Re: Broke a stock axle @ the track; happen to anybody else? [Re: olwhite64] #1066306
08/31/11 12:20 PM
08/31/11 12:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Go to the bone yard and see what you can find...
you dont want the HEAVY DUTY one.... the tubes are
THICK
Re: Broke a stock axle @ the track; happen to anybody else? [Re: olwhite64] #1066307
08/31/11 09:31 PM
08/31/11 09:31 PM
NC
440Jim Offline
440Jim  Offline
NC
I broke a stock axle on my 3700 lb 1973 Barracuda with 440, 3900 converter, 1.55 sixty foot, 8-3/4 rear, suregrip, slicks. I don't remember exactly, but maybe 150 passes. Aftermarket axles after that and no problems.
Re: Broke a stock axle @ the track; happen to anybody else? [Re: 440Jim] #1066308
08/31/11 09:42 PM
08/31/11 09:42 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I ran resplined axles with a sure grip for over 15 years 11.60@3800lbs. They had 1 spline of twist when replaced. I also ran 12.50@3750lbs with a stick for about 100 passes with the same amount of twist. Both on slicks.
Doug
