soldering wires, what 2 use #1064093
08/28/11 12:22 AM
08/28/11 12:22 AM
RapidRobert Offline OP
Some heavy wires, soldering gun & even the big iron was too light & tried propane but the flame is too wide & wants 2 melt the insulation at either end of the joint. Any suggestions? Thank you 4 your time
Re: soldering wires, what 2 use [Re: RapidRobert] #1064094
08/28/11 12:30 AM
08/28/11 12:30 AM
Wendy, I'm home.
dstryr Offline
dstryr  Offline
Wendy, I'm home.
roll a piece of sheet metal into a cylinder or cone to direct the flame.
dstryr, since 1986.
Re: soldering wires, what 2 use [Re: RapidRobert] #1064095
08/28/11 12:31 AM
08/28/11 12:31 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
For 4-8 ga wire I typically use a crack pipe lighter...
Re: soldering wires, what 2 use [Re: dstryr] #1064096
08/28/11 12:36 AM
08/28/11 12:36 AM
That's outside the box but I'm game. RT what kind of fuel
Re: soldering wires, what 2 use [Re: RapidRobert] #1064097
08/28/11 12:47 AM
08/28/11 12:47 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Butane.. Hit up your local Rockstar...
Re: soldering wires, what 2 use [Re: 1_WILD_RT] #1064098
08/28/11 12:50 AM
08/28/11 12:50 AM
I'm assuming the flame can b turned down low. Alright I'll go get one (but not from my crack head neighbors)
Re: soldering wires, what 2 use [Re: RapidRobert] #1064099
08/28/11 09:13 AM
08/28/11 09:13 AM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
Here is the setup I use, pretty slick.
Re: soldering wires, what 2 use [Re: T2R9] #1064100
08/28/11 10:02 AM
08/28/11 10:02 AM
Yeah that looks worthwhile (refillable/diff tips)
Re: soldering wires, what 2 use [Re: RapidRobert] #1064101
08/28/11 01:01 PM
08/28/11 01:01 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
i have thia cool little setup that is a mini torch that that a rechargeable butane lighter in it. bought it years ago and works like a charm
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: soldering wires, what 2 use [Re: RapidRobert] #1064102
08/28/11 01:06 PM
08/28/11 01:06 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I soldered some 10 ga wire last night onto a couple alligator clips for a 12volt contractor fuel pump in the bed of my pickup truck.
I used a gun type soldering gun and was able to easily have enough heat to get the allligator clips hot enough to flow the solder out. These clips go on 12V batterys, they are not small.
If the wire is corroaded or dirty it won't take solder.
I work on petroluem tanker trucks everyday, those hand held torches are scaring the crap out of me.
Re: soldering wires, what 2 use [Re: Challenger 1] #1064103
08/28/11 01:19 PM
08/28/11 01:19 PM
hooziewhatsit Offline
you did put a blob of melted solder on the tip of the iron, then put it on the wire(s) to be soldered, right? If the tip is clean, it won't transfer hardly any heat.
Otherwise, strip the insulation back an inch or two, then clamp small vice grips on either side of the joint. They'll absorb most of the heat and prevent it from messing up the insulation. Then slide your shrink tubing (that you put on before solding the joint) over the entire joint.
Re: soldering wires, what 2 use [Re: hooziewhatsit] #1064104
08/28/11 01:30 PM
08/28/11 01:30 PM
Yes I did clean the tip then coated it. I think the prob w that there was just enough breeze (dont take much) drawing away heat but it was aggravating. I dont get frustrated very often but this deal got 2 me a bit. Thanks again guys
Re: soldering wires, what 2 use [Re: RapidRobert] #1064105
08/28/11 01:34 PM
08/28/11 01:34 PM
Cincinnati, Ohio
Cincinnati, Ohio
In addition to tining the iron you must tin the wires also first, then it's a easy deal to stick the 2 togeather with minimal heat.
Re: soldering wires, what 2 use [Re: RapidRobert] #1064106
08/28/11 01:36 PM
08/28/11 01:36 PM
crlush Offline
crlush  Offline
I bought a cheap refillable pencil type butane torch, works great but you have to refill quite often but no big deal
Re: soldering wires, what 2 use [Re: Challenger 1] #1064107
08/28/11 01:40 PM
08/28/11 01:40 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Make sure you have a good mechanical connection first... tin/lead solder tends to fracture under high vibration (like an automotive application) especially if it's in tension.
If you've got room, perhaps one of these? They come in many sizes...
Re: soldering wires, what 2 use [Re: DrCharles] #1064108
08/28/11 01:43 PM
08/28/11 01:43 PM
Cincinnati, Ohio
Cincinnati, Ohio
Oh yea that'll look good on my dragster...light weight too.
Next thing you know we will have scrappers stealing stuff off our cars if we used connections like that.imo
Re: soldering wires, what 2 use [Re: Challenger 1] #1064109
08/28/11 01:50 PM
08/28/11 01:50 PM
You know I'm wondering if I DIDN'T tin both wires enough . (& I'm always preaching k.i.s.s./basics) I'll b back on it today. Charles that clamp oughta do it but I'd (prob) still wanna solder it & if it's as big as it looks I'd be dragging out the acetylene
Re: soldering wires, what 2 use [Re: RapidRobert] #1064110
08/28/11 02:14 PM
08/28/11 02:14 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Come on, you're thinking of the fist-sized ones for industrial power lines... a small split-bolt like you need for two #10 wires weighs a whopping half ounce! Won't cost you too many tenths ET
Re: soldering wires, what 2 use [Re: RapidRobert] #1064111
08/28/11 03:20 PM
08/28/11 03:20 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
those lugs come in pretty small sizes (home depot or such)and are you using rosin core solder or solid?
Re: soldering wires, what 2 use [Re: mikemee1331] #1064112
08/28/11 03:25 PM
08/28/11 03:25 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Another almost obvious suggestion when at the limits of heat input, orient the wire vertically, with the insulation on the bottom, and allow heat to rise.
