Where can I get an aluminum head repaired??? #1063823
08/27/11 11:19 AM
08/27/11 11:19 AM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
We have one W5 head that keeps giving us fits. They are the supposedly "good" castings, and have been CNC ported. We got around 50 passes on the first engine when we started having water issues. Pulled the engine apart, found a leak in one of the intake ports. We sent the head off and had it repaired (epoxy of some sorts), re-did the short block, and probably had around 100 passes on it before it failed again (epoxy came out). When it went this time it flooded the engine so bad it stalled when turning on the return road. Can this head be fixed so that we can enjoy this engine at least for a little bit? We actually left a little on the table hp wise so we would have a nice, powerful, but trouble free engine that we could enjoy for many years. If we'd known we were going to be pulling it every year we would have set it on kill! It's on my dads engine and the parts are in SoDak so anywhere close to their would be a +, but we just want it DONE so that it lasts!
Re: Where can I get an aluminum head repaired??? [Re: J_BODY] #1063824
08/27/11 01:54 PM
08/27/11 01:54 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Harrys in sewer city ?
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Where can I get an aluminum head repaired??? [Re: J_BODY] #1063825
08/27/11 02:37 PM
08/27/11 02:37 PM
How about Jeff at Modern Cylinder head or Shady Dell or Ryan in N.Y.?I know several shops out here on the west coast but Jeff is nearer to the car
Re: Where can I get an aluminum head repaired??? [Re: Cab_Burge] #1063826
08/28/11 12:05 AM
08/28/11 12:05 AM
Jeff mentioned above has beeen having health problems.
I would give Radar a call, he is close.
Roger "Radar' Lechtenberg at R@J performance ( 319)-988-3595 , 4611 South Hudson Road Cedar Falls iowa 50613,
He has been at it a long time and knows Mopar heads.
Re: Where can I get an aluminum head repaired??? [Re: ] #1063827
08/28/11 08:38 PM
08/28/11 08:38 PM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
Think we'll try giving him a call eh100. Who's "Harry's" Big?
Re: Where can I get an aluminum head repaired??? [Re: J_BODY] #1063828
08/28/11 10:10 PM
08/28/11 10:10 PM
Another real nice guy that is a little closer is Larry Demers. He has a nice shop in the back of the NAPA store he owns in Carrol IA. I just don't know how familiar he is with the "W" head. If the sprint car guys run them I'm sure he has seen them.
Don't know if he will be in the shop tomarrow. He runs a TOP sportsman car and his son runs SC pipe rack. Both were racing at Topeka this weekend.
Re: Where can I get an aluminum head repaired??? [Re: J_BODY] #1063829
08/28/11 10:39 PM
08/28/11 10:39 PM
long island newyork
Abodyjohn88 Offline
Abodyjohn88  Offline
long island newyork
how do they go anout fixing an aluminum head???? epoxy luike said above?? or do they do a special type of elding than port the cylinder back out'.
Re: Where can I get an aluminum head repaired??? [Re: J_BODY] #1063830
08/28/11 10:44 PM
08/28/11 10:44 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Maybe you can fix it yourself. If they were using Epoxy to try and fix it a product called Alumiweld may be much better. It needs no flux or argon to make it work. The average joe can do it with a torch. It melts at about 750*
BUT!! So far Ive only done minor tests with it with positive results.
Now the Bad news, Its sold at Harbor Freight.
Im going to try and use it on a Yamaha Rhino aluminum radiator that was repaired at a Radiator shop that failed with some kind of goo Epoxy.
After my failures with, sodder, JB weld, and my Mig welder with aluminum wire. My tests with the alumiweld show very promising results, IMO
It may be the fix for you also. It should be Waay better then any Epoxy job from my test results.
Re: Where can I get an aluminum head repaired??? [Re: Sport440] #1063831
08/28/11 10:55 PM
08/28/11 10:55 PM
Denison,Ia.
Cuda367 Offline
Cuda367  Offline
Denison,Ia.
I was in topeka with Larry Demers this weekend and he has done a truck load of head repair. 712-792-4381
Re: Where can I get an aluminum head repaired??? [Re: Cuda367] #1063832
08/29/11 12:33 AM
08/29/11 12:33 AM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
Thanks for the info eh100 and good to hear a recommendation from you too Richard. If it wasn't so damn fun to have a 9 sec small block running exhaust we'd given up by now.
Re: Where can I get an aluminum head repaired??? [Re: Sport440] #1063833
08/29/11 12:42 AM
08/29/11 12:42 AM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
Maybe we could..... but I don't want to "experiment" when it involves removing the engine, tearing it down, inspecting, and cleaning up the mess this is making. I'm just hoping someone can look at it and tell us with confidence that it can be fixed for good. We still have our 360 sitting complete that was good for high 10's on good air days. Worse part about this is being 1300 miles away. I'd love to be able to travel a couple hours and help my dad with this mess on a weekend.
Re: Where can I get an aluminum head repaired??? [Re: J_BODY] #1063834
08/29/11 12:53 AM
08/29/11 12:53 AM
tboomer Offline
tboomer  Offline
Jay...I took a set of Eddy Victors to Radar for Lonemopar...One was banged up pretty bad!! He had them done up nicely!!
Re: Where can I get an aluminum head repaired??? [Re: tboomer] #1063835
08/29/11 01:11 AM
08/29/11 01:11 AM
Sterling Heights, MI
MCHBOB Offline
MCHBOB  Offline
Jeff Has been doing great.Very busy.Is the leak from a hole or a crack?And how close to the seat is it.
Take a pic and post if you could
Re: Where can I get an aluminum head repaired??? [Re: Cuda367] #1063836
08/29/11 09:02 AM
08/29/11 09:02 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I'll vote for Larry too
Harrys Heads
http://www.manta.com/c/mm5sg6v/harry-heads-auto-machine-inc
Re: Where can I get an aluminum head repaired??? [Re: bigdad] #1063837
08/29/11 12:58 PM
08/29/11 12:58 PM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
Sent my dad the contact info for Larry. Talked to him this am so hoping for the best.
Re: Where can I get an aluminum head repaired??? [Re: J_BODY] #1063838
09/08/11 01:37 PM
09/08/11 01:37 PM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
.....of course! Leak in a very tricky spot on the short side. We're sending him a "test" head to look at and cut apart if need be. May have to repair from the back side. In the mean time we just bought another set of W5's so we'll get those done up and hopefully make a pass or two yet this fall. Guess we're in this deep... what's a little more.
Re: Where can I get an aluminum head repaired??? [Re: J_BODY] #1063839
11/02/11 09:44 PM
11/02/11 09:44 PM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
W5 still at the hospital. We're in no hurry. We sent him some cut up sections of a W-5 head and it's been determined that he is going to cut a section out of the deck and weld up the short turn from the backside, psi test it, and then repair and resurface the deck. Meanwhile the engine is being assembled with our "new" set of W5s.
Re: Where can I get an aluminum head repaired??? [Re: J_BODY] #1063840
11/03/11 10:29 AM
11/03/11 10:29 AM
Windsor ,Ca.
K
Keith Richards Offline
K
Windsor ,Ca.
You could send it up to Angie at Mopar Engines West in Nor Cal, I had a piston / rod assembly chew one up pretty good last year and after she worked her magic you would never know.
Number and email if interested maybe send a picture and get a quote? if so tell her Keith set you.
1-510-796-4313 or angie-moparengines@sbcglobal.net
Re: Where can I get an aluminum head repaired??? [Re: Keith Richards] #1063841
11/03/11 11:29 PM
11/03/11 11:29 PM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
Head is already in capable hands Keith, but thanks for chiming in on a suggested repair facility.
Re: Where can I get an aluminum head repaired??? [Re: J_BODY] #1063842
11/04/11 02:07 PM
11/04/11 02:07 PM
Central Iowa
SSDA5006 Offline
SSDA5006  Offline
Central Iowa
For future reference:
Midwest Cylinder Heads
Nevada, Iowa
Lots of performance machine shops use them.
http://midwestcylinderhead.com/
I've used them for the head repair and then Harry Heads, Sioux City,IA for the final porting/epoxy work.
