Page 1 of 3 1 2 3
mopar R block and well known head porter #1062291
08/24/11 06:18 PM
08/24/11 06:18 PM
mass
K
kotacars Offline OP
kotacars  Offline OP
K
mass
If you bought a used 340 R block from a well known engine builder but you didn t build the engine till 4 years later at which time you found out the block was no good would you expect that shop to make it right. Well the simple solution to my problem would be to get another block 59 degree 9.600 deck bore smaller
Then 4.125. This block is good just needs new lifer bushings and 4.135 bore pistons Ryan has offer to rebush free of charge which is very good of him but does fix my total problem so if any has a block for sale please help a fellow mopar nut out
Re: mopar R block and well known head porter [Re: kotacars] #1062292
08/24/11 06:30 PM
08/24/11 06:30 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Depends on if the issue was mopars issue, and if the machinist had anything to do with the issues at at hand.
Whats the deal?
Kasey
Re: mopar R block and well known head porter [Re: kotacars] #1062293
08/24/11 06:31 PM
08/24/11 06:31 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
I wouldn't. The block should have been checked out at the time of purchase.
Re: mopar R block and well known head porter [Re: sixpakdodge] #1062294
08/24/11 06:38 PM
08/24/11 06:38 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
4 years? Come on
4 weeks maybe
Re: mopar R block and well known head porter [Re: Moparnut426] #1062295
08/24/11 06:39 PM
08/24/11 06:39 PM
mass
K
kotacars Offline OP
kotacars  Offline OP
K
mass
The shop I bought it from did the machine work and the specs also assured me the blck was good.
Re: mopar R block and well known head porter [Re: kotacars] #1062296
08/24/11 06:41 PM
08/24/11 06:41 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I would hope to think that he would take care of it,but you may have to jump thru a few hoops to prove your point that it was junk to start with, and only expect a replacement block as a fair deal cause lot's of shops won't do a cash back deal,,especially after this many years,,,,,good luck, and let us know how it turns out for you.
Re: mopar R block and well known head porter [Re: dartman366] #1062297
08/24/11 06:42 PM
08/24/11 06:42 PM
Moparnut426 Offline
Moparnut426  Offline
Whats wrong with this one?
Kasey
Re: mopar R block and well known head porter [Re: Leon441] #1062298
08/24/11 06:45 PM
08/24/11 06:45 PM
mass
K
kotacars Offline OP
kotacars  Offline OP
K
mass
4 years? Come on
4 weeks maybe
lost my job couldn t finish the build did not retrun to work for 2 years so I just sat on the parts and the shop I bought it from did the machine work.
Re: mopar R block and well known head porter [Re: kotacars] #1062299
08/24/11 06:54 PM
08/24/11 06:54 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
What do you mean, block is no good? 4 years is stretching it working or not.
I will edit this and add...If it was completely blown up and scattered, when they said a good block, that would warrant a trip to the guys shop
Re: mopar R block and well known head porter [Re: kotacars] #1062300
08/24/11 06:57 PM
08/24/11 06:57 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Not enough details, i think your stuck with it
Re: mopar R block and well known head porter [Re: ademon] #1062301
08/24/11 07:01 PM
08/24/11 07:01 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
50mm cam tunnel, 59º lifters?
Re: mopar R block and well known head porter [Re: S/ST 3040] #1062302
08/24/11 09:45 PM
08/24/11 09:45 PM
Delray beach, Florida
P
Performance Only Offline
P
why so secretive? tell us what's wrong with it.
machine shop owner and engine builder
Re: mopar R block and well known head porter [Re: Performance Only] #1062303
08/24/11 10:08 PM
08/24/11 10:08 PM
mass
K
kotacars Offline OP
kotacars  Offline OP
K
mass
well for one I order pistons based on what he told me the bore size was but its 010 bigger and the lifters bushings are out of round and have a tapper and the 750 dollar roller lifters I bought from him the bodies have a 0015 tapper
Re: mopar R block and well known head porter [Re: kotacars] #1062304
08/24/11 10:47 PM
08/24/11 10:47 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Ordering pistons based on what you are told is a mistake.
The lifter bores maybe that is something.
You told me you had Morrel lifters. I'm not sure about your price, $750. Like I told you on the phone about the this.
The block is not junk. I think that should be cleared up.
Go ahead and spill the beans. Ryan sold you the block. I don't think Ryan would have a problem with people knowing this. After all, the only thing we are absolutely clear on is there was a discrepency in the bore of the block. You remember being told 4.125". Now you think it is actually 4.135". Before I spent $1,500 on pistons I would have been absolutely sure. But, like I told you we all screw up. If so, this was an expensive one.
I have trouble with this as some of the prices you have paid for parts seem off. But, I was not on either end of the deal.
Ryan is a pretty busy guy, but, I'm sure he will work with you on this. If the lifter bores are out of round I think he would take care of that. But, I'm not in this deal so I am purely speculating.
Leon
Re: mopar R block and well known head porter [Re: Leon441] #1062305
08/24/11 10:53 PM
08/24/11 10:53 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
so how can you tell if a lifter bore is out of round but you cant measure a large piston bore before you order a set of high $$$ pistons. I seriously doubt the lifter bores are out of round
Re: mopar R block and well known head porter [Re: Leon441] #1062306
08/25/11 05:48 AM
08/25/11 05:48 AM
mass
K
kotacars Offline OP
kotacars  Offline OP
K
mass
Leon
The price on the Lifters is what Ryan charged me and all this info is coming from the machine shop it is at now Larrys Auto Machine in Ct
Re: mopar R block and well known head porter [Re: kotacars] #1062307
08/25/11 06:50 AM
08/25/11 06:50 AM
Guitar Jones Offline
Maybe a trip to Larry's is in order so he can show you for yourself. Machine shops have been known to exagerate a bit about some things in order to get more work and more money. And .0015 taper on a lifter body? OMG, that thing will spew chunks everywhere.
Re: mopar R block and well known head porter [Re: Guitar Jones] #1062308
08/25/11 07:20 AM
08/25/11 07:20 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
How many of you are running Morrel lifters? Have you had trouble with your being out of round?
I have been running the same set sense 2007 when Ryan rebushed my R3 block. I have never checked the lifter bushings or the lifters to be honest. I plan to check them today sense my engine is apart. Not saying it can't happen because we all know that even the best stuff can be screwed up. All I know is my experience with turning 9K and I had no trouble with my own.
I understand the block in question came from another shop in a buyout. This guy also did lifter bushings and stuff. So really don't know all the facts. I'm sure like everything out there you can buy different variations of the same brand parts. Maybe these Morrels are different than the ones most of us have came to love.
How about some pics if possible.
And I have to agree we don't know the shop who has it now. So it's just thier word as far as we know.
Course we don't know what Ryan has to say about this or what he remembers as far as the deal. It may be bad deal on his part.
Maybe it is none of our business and should not have been put on here to start with.
Leon
Re: mopar R block and well known head porter [Re: Guitar Jones] #1062309
08/25/11 07:34 AM
08/25/11 07:34 AM
mass
K
kotacars Offline OP
kotacars  Offline OP
K
mass
I was told .0003 tapper is exceptable and I am pretty sure I measured the top of the bore before ordering the pistons. Yes I am taking a ride to the machine shop to day to see what's what and get my parts back either way because my gut is telling me something just isn t right.
Re: mopar R block and well known head porter [Re: kotacars] #1062310
08/25/11 08:54 AM
08/25/11 08:54 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Page 1 of 3 1 2 3
