Difference between3/8 b & E body fuel sending unit?
#106053
08/16/08 08:13 PM
08/16/08 08:13 PM
is the float arm on a fuel sending unit longer on a e body compared to a b body? or better yet, what is the difference between the 2 fuel sending units. i think the restoration shop i brought the car to put in the wrong sending unit, i cant get a full reading on it, when i take it out and test it it works fine, but the arm seems way too long for a b body gas tank.i think the float arm is hitting the top of the tank. thanks
Re: Difference between3/8 b & E body fuel sending unit
[Re: JohnRR]
#106055
08/18/08 03:24 PM
08/18/08 03:24 PM
i filled mine up yesterday. it reads a little over 3/4 full. just bought it too
#106056
08/18/08 09:59 PM
08/18/08 09:59 PM
i take it out of the car and it works fine, put it back in and it reads a little less than 3/4" full of gasup to the top. whats the chance of the float hitting the top of the gas tank inside?
#106057
08/19/08 08:54 AM
08/19/08 08:54 AM
Posts: 75,058 U.S.S.A.
JohnRR
U.S.S.A.
whats the chance that you are raising it to the exact same height outside the tank that it's going to inside the tank ???
[Re: bbodybill]
#106059
08/19/08 03:48 PM
08/19/08 03:48 PM
JohnRR
U.S.S.A.
Would a picture of an Ebody sending unit help?? Have the unit handy.. Bill
sure will
[Re: JohnRR]
#106060
08/19/08 04:49 PM
08/19/08 04:49 PM
Posts: 228 So. Calif.
bbodybill
So. Calif.
sure will
Two pics (hopefully).. Resized.. Originals avail via Email... Moparts doesn't seem to like my photos :-(
[Re: bbodybill]
#106062
08/19/08 05:58 PM
08/19/08 05:58 PM
Second pic
that looks like a e body one. seems to me that the float is hitting the top of the gas tank because the float rod looks awefully long. is there a chance all these chinese made sending units which everyone is buying are having the same problems. i noticed that alot of guys are having the same problem with malfunctioning gas gauges.
#106063
08/19/08 06:25 PM
08/19/08 06:25 PM
what you need to do is fill the tank, find where the gas gauge reads. run the tank down low so you can remove the unit.
Connect the unit to the sending gauge wire and move the arm to the top. did it read full? if so, your in luck- just bend the arm lower so the float doesnt hit the top of the tank when its full.
#106064
08/19/08 08:57 PM
08/19/08 08:57 PM
that wont work because it messes up the empty side and then the arm wont hit the stop tabs. if only i could shorten the float rod, then it would work.
#106065
08/20/08 09:25 AM
08/20/08 09:25 AM
JohnRR
U.S.S.A.
or bend the float rod
ahave you looked into the tank with it full and actually SEEN the float touching the top of the tank ?
[Re: JohnRR]
#106066
08/20/08 07:05 PM
08/20/08 07:05 PM
IS THAT a trick question?
#106067
08/21/08 09:08 AM
08/21/08 09:08 AM
JohnRR
U.S.S.A.
no , it's a SERIOUS question , you are ASSuMEing that it's hitting the top of the tank , unless you have actually LOOKED INSIDE with the tank installed in the car and full of fuel how do you truly know ???
just bend the rod , it's not that hard to do .
[Re: JohnRR]
#106068
08/23/08 10:33 AM
08/23/08 10:33 AM
john, you canonly go so far with gas with the sending unit removed otherwise the gas is going to pour out the hole, unless im missing something here, im lucky to have a 1/4 gas in it without the sending unit in place. dont know how i can check it with a full tank of gas!!!
#106069
08/23/08 12:43 PM
08/23/08 12:43 PM
JohnRR
U.S.S.A.
You could cut a hole in the trunk floor and the top of the tank to look in , don't cut the top off above the float , make the hole big enough to get your head in and wear swim fask so you can see the float ...
All the time you wasted about this you could have tweaked the float arm and rechecked it .... twice ...
[Re: JohnRR]
#106070
08/23/08 10:19 PM
08/23/08 10:19 PM
Posts: 1,630 Burma Shave
plymouthfan
Burma Shave
I have the same problem... reads only 3/4 full. John, if I don't have a swim mask, will goggles and a snorkel work?
One red car, one yellow car.
[Re: plymouthfan]
#106071
08/24/08 06:02 PM
08/24/08 06:02 PM
JohnRR
U.S.S.A.
yes that would be better as you wouldn't have to hold your breath
[Re: plymouthfan]
#106072
08/24/08 08:00 PM
08/24/08 08:00 PM
Posts: 18,424 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Make sure your snorkel has a viton ball or else it will soften in the gas and stick.
