70 challenger 383-originally blue engine #1059864
08/23/11 07:07 AM
08/23/11 07:07 AM
western australia
1cuda Offline OP
1cuda  Offline OP
western australia
found a numbers 383 challenger for a friend of mine-when i checked the numbers i noticed it had blue under the orange engine-it`s not an air con car and it was built dec 69 in l.a. anyone got a blue 383 in 1970 with no air con? i`m sure it should be orange but it was definitely blue. it`s a low mile original and all numbers are correct.
all the best
frank.
Re: 70 challenger 383-originally blue engine [Re: 1cuda] #1059865
08/23/11 07:35 AM
08/23/11 07:35 AM
Mass
charge70 Offline
charge70  Offline
Mass
Is the engine code L or N.It would be blue if it's an L code,383 2bbl.N code,383 4bbl would be orange. John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: 70 challenger 383-originally blue engine [Re: 1cuda] #1059866
08/23/11 07:37 AM
08/23/11 07:37 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
A '70 Challenger (JH23N0/JH27N0) or Challenger SE (JH29N0) with a 383 4bbl ("N" - code) should be a non-HP 330 horsepower Carter AVS equipped blue engine with an automatic.
A '70 Challenger (JH23N0/JH27N0) or Challenger SE (JH29N0) with a 383 4bbl ("N" - code) should be a HP 335 horsepower Holley equipped orange engine with a 4-speed.
Is the top pad stamped "HP"? Any chance there is a broadcast sheet?
Re: 70 challenger 383-originally blue engine [Re: 6bblgt] #1059867
08/23/11 08:49 AM
08/23/11 08:49 AM
western australia
1cuda Offline OP
1cuda  Offline OP
western australia
i should have given more information-it is an r/t js23n0e car. it doesn`t have the original intake and carburator but it does have the correct exhaust manifolds. the engine vin is correct and that`s where i first saw it was blue under the orange. the pad on the top is all correct-it has the full date as in 102469 as in oct 24th 1969. i can`t remember if it has hp-i will look at it tomorrow and give you full details of the numbers. the 4 speed has the vin also and the 10000 date code is correct. it has a 3.23 sure grip rear. the fender tag and cowl vin and dash vin and radiator support vin all are correct. it has had one paint job over the original b5 and it has never been apart. no buildsheet-looked under dash behind front seat backs and behind rear seat and under rear seat-nothing-it is an l.a car so maybe no buildsheet.
i will get some more numbers.
thanx
frank.
Re: 70 challenger 383-originally blue engine [Re: 1cuda] #1059868
08/23/11 01:06 PM
08/23/11 01:06 PM
Farmington, CT
KISSAlien Offline
KISSAlien  Offline
Farmington, CT
AFAIK. All R/T 383s should be HP motors and thus orange, even with 3.23s and an automatic.
Re: 70 challenger 383-originally blue engine [Re: KISSAlien] #1059869
08/23/11 02:33 PM
08/23/11 02:33 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
All of the engines in 383 4-bbl '70 performance badged Mopars were orange.
Challenger R/T, Super Bee, Charger, 'Cuda, & Road Runner.
An October "engine assembly date" sounds early for a December built car.
I've never seen a "top pad" with the year of assembly stamped "69".
Is this the same car as your other post about the 4-speed?
If so, the above quote seems at odds with the transmission being painted orange.
Got pics? Is it a factory "EXPORT" car?
Re: 70 challenger 383-originally blue engine [Re: 6bblgt] #1059870
08/23/11 03:41 PM
08/23/11 03:41 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I agree have not seen year of assembly stamped on the pad , do you have pictures of all the stampings on the engine and trans ?
Re: 70 challenger 383-originally blue engine [Re: JohnRR] #1059871
08/24/11 02:23 PM
08/24/11 02:23 PM
western australia
1cuda Offline OP
1cuda  Offline OP
western australia
thanx for the input-i should have got pics before i started this post. attached are some pics but i couldn`t get a clear pic of i.d pad. the car vin is js23n0e119229. the i`d pad reads f383. under that is says 10(oct) then a large space and then 312(31st oct) 2nd shift. at the bttom is says hp. the 4 speed has 0e119229-the 9 is stamped very lightly. pp833 3009 0288.
fender tag
end
n42 n85 r22 v1x v68 y14
v1x a62 c55 j25 m21 n41
eb5 h6x9 000 b12 053579
e63 d21 js23n0e119229
i know it`s a numbers car but it has blue under the orange on the block. galens book says blue for a 330 hp 383 n code.
is there anything out of place with the info or pics?
please let me know any thoughts people have-i doubt that it was rebuilt and painted blue and then painted orange in later years.
all the best
frank.
Re: 70 challenger 383-originally blue engine [Re: 1cuda] #1059872
08/24/11 02:28 PM
08/24/11 02:28 PM
western australia
1cuda Offline OP
1cuda  Offline OP
western australia
4 speed pic
Re: 70 challenger 383-originally blue engine [Re: 1cuda] #1059873
08/24/11 02:29 PM
08/24/11 02:29 PM
western australia
1cuda Offline OP
1cuda  Offline OP
western australia
fender tag - sorry i said dec 69 on my first post-try nov 12-got too many numbers spinning through my head at the moment.
thanx again
frank.
Re: 70 challenger 383-originally blue engine [Re: 1cuda] #1059874
08/24/11 03:22 PM
08/24/11 03:22 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Frank,
That blue you see by the serial number pad might just be a paint swab. Motors have all kinds of writting and marks on them before paint.
Morty
Re: 70 challenger 383-originally blue engine [Re: 1cuda] #1059875
08/24/11 03:34 PM
08/24/11 03:34 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
..... -i doubt that it was rebuilt and painted blue and then painted orange in later years.
It's been 40+ years, a lot can happen in that time. If you investigate it further, I'd bet this is what you'd find. Strip a valve cover (do they appear to be original?) last layer of paint off, or stubborn spots should be orange.
Re: 70 challenger 383-originally blue engine [Re: 1cuda] #1059876
08/24/11 08:12 PM
08/24/11 08:12 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I'm ASSuMEing that you incorrectly THOUGHT that the id pad showed the year in the assembly date , if that is the case then what you say that i quoted in BOLD would be the correct way of stamping the ID pad .
Re: 70 challenger 383-originally blue engine [Re: JohnRR] #1059877
08/24/11 08:42 PM
08/24/11 08:42 PM
western australia
1cuda Offline OP
1cuda  Offline OP
western australia
johnrr-you are 100% correct-i should have had all the info in front of me before i asked the question. there seems to be blue in many areas of the engine so that`s what i`m trying to work out or even make me and others more knowledgable on what was actually made. what are people`s thoughts on galens white book page 1 parts & casting book it says blue under 383 for 1970 but with air con-this is not an air con car. on his option code book page 18 it says 330hp engine was blue and the 335hp engine was orange-could it have a 330hp engine or not in an r/t? or was it 70 383 r/t only had 335hp engines that were orange?
yes-one day the engine will come out and then i`ll look a lot closer than i can now-i will ask again in a few years time.
thanx for the responses
frank.
Re: 70 challenger 383-originally blue engine [Re: 1cuda] #1059878
09/28/11 03:30 AM
09/28/11 03:30 AM
Europe
BB 70 Challenger Offline
Europe
Great info !
I have a "factory EXPORT car". VIN JH23N0Bxxx so, itīs not a RT, but 330hp four barrell 383 car.
Non-AC, automatic, AVS card, blue (turquoise) engine. Exported to Europe in 12/1969, still here, for good.
Re: 70 challenger 383-originally blue engine [Re: BB 70 Challenger] #1059879
09/28/11 04:54 AM
09/28/11 04:54 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
The '70 big-blocks are the first year for the "Chrysler Blue" engine paint. When it's old & dirty it resembles turquoise.
1969 is the last year for the "turquoise" engine paint.
Can you share the fender tag info for your EXPORT - JH23N0B?
Re: 70 challenger 383-originally blue engine [Re: 6bblgt] #1059880
09/28/11 02:59 PM
09/28/11 02:59 PM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
My friend just took some pictures yesterday of his 70 Challenger matching numbers,383 N code SE,and the engine is blue. It has the 383 four barrel emblems on the fenders below the center body line just below where the Challenger emblems are.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: 70 challenger 383-originally blue engine [Re: chargervert] #1059881
09/28/11 03:42 PM
09/28/11 03:42 PM
Crook County, ILL
Mastershake340 Online content
Mastershake340  Online Content
Crook County, ILL
I saw my Challenger 383 4 barrel's brother at the Monster Mopar weekend last week, and he'd painted his engine this blue, does this look to be the correct blue, it looked pretty bright!
Re: 70 challenger 383-originally blue engine [Re: Mastershake340] #1059882
09/28/11 03:51 PM
09/28/11 03:51 PM
chargervert Offline
chargervert  Offline
It looks like the same color that the one is in my friends 383 SE is.
Re: 70 challenger 383-originally blue engine [Re: chargervert] #1059883
09/28/11 04:00 PM
09/28/11 04:00 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
It looks about right - here's a pic of the freshly painted valve covers on my old 383 2bbl '70 S/23.
