440 motor home engine,spark plug ? #1059050
08/21/11 11:50 PM
08/21/11 11:50 PM
RI Deep in the rust belt
chargervert Offline OP
I bought a freshly rebuilt 440 engine that came out of a 78 Winnabego motor home. I installed it today in the Chargervert,while I rebuild the 440 that came out of the car. I bought a set of spark plugs for a 70 440 and the don't fit. Did the later 440s take a different plug? If so does anybody have a plug number,so I can get plugs that fit? Any info would be a great help. Thanks Pete.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: 440 motor home engine,spark plug ? [Re: chargervert] #1059051
08/21/11 11:59 PM
08/21/11 11:59 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Yep, some motorhomes took a different plug even with the 452 head casting...No compression washer and possibly a different size{smaller} IIRC...Could'nt NAPA{or local auto parts} cross it over for you ???
Re: 440 motor home engine,spark plug ? [Re: chargervert] #1059052
08/22/11 12:26 AM
08/22/11 12:26 AM
Brandon, Ms
cornet684me Offline
cornet684me  Offline
Brandon, Ms
i had the same problem, the motor home 440 have a different head, you have to use different plugs, i have 1973 motor home 440, i have to use autolite AP 26 or A/C Delco R44TS, you may can cross reference these numbers and get the brand of plug you want to run
Re: 440 motor home engine,spark plug ? [Re: cornet684me] #1059053
08/22/11 05:37 AM
08/22/11 05:37 AM
scratchnfotraction Offline
yep,it would be the small 5/8" hex,tapperd seat (peanut plug)
i run autolight 23 in my 78 440 MH engine
Re: 440 motor home engine,spark plug ? [Re: scratchnfotraction] #1059054
08/22/11 06:54 AM
08/22/11 06:54 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: 440 motor home engine,spark plug ? [Re: 340SHORTY] #1059055
08/22/11 09:06 AM
08/22/11 09:06 AM
Thanks guys,I bought a set of Autolite 85 plugs,but I have ten other cars I can use them in,so they won't go to waste. The smaller peanut plugs will actually be a blessing,as the larger plugs are really tight fitting with the headders I have.
