440 motor home engine,spark plug ?
#1059050
08/21/11 11:50 PM
08/21/11 11:50 PM
Posts: 15,995 RI Deep in the rust belt
chargervert
I bought a freshly rebuilt 440 engine that came out of a 78 Winnabego motor home. I installed it today in the Chargervert,while I rebuild the 440 that came out of the car. I bought a set of spark plugs for a 70 440 and the don't fit. Did the later 440s take a different plug? If so does anybody have a plug number,so I can get plugs that fit? Any info would be a great help. Thanks Pete.
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
Re: 440 motor home engine,spark plug ?
[Re: chargervert]
#1059052
08/22/11 12:26 AM
08/22/11 12:26 AM
Posts: 1,639 Brandon, Ms
cornet684me
Brandon, Ms
i had the same problem, the motor home 440 have a different head, you have to use different plugs, i have 1973 motor home 440, i have to use autolite AP 26 or A/C Delco R44TS, you may can cross reference these numbers and get the brand of plug you want to run
[Re: cornet684me]
#1059053
08/22/11 05:37 AM
08/22/11 05:37 AM
Posts: 15,487 Florida
scratchnfotraction
yep,it would be the small 5/8" hex,tapperd seat (peanut plug)
i run autolight 23 in my 78 440 MH engine
[Re: 340SHORTY]
#1059055
08/22/11 09:06 AM
08/22/11 09:06 AM
chargervert
Thanks guys,I bought a set of Autolite 85 plugs,but I have ten other cars I can use them in,so they won't go to waste. The smaller peanut plugs will actually be a blessing,as the larger plugs are really tight fitting with the headders I have.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
