Water starting to drip from right side under the dash? #1058587
08/21/11 01:25 PM
08/21/11 01:25 PM
Morgantown, WV
1970 Drop Top Offline OP
Morgantown, WV
My daughter and I was driving from a car show on Saturday. She notice a few drops of water dripping on her feet. It looks like it is comming from around the heater core area. I don't not smell antifreeze yet. Any suggestions?
Re: Water starting to drip from right side under the dash? [Re: 1970 Drop Top] #1058588
08/21/11 01:29 PM
08/21/11 01:29 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Were you running the A/C? If not yes it has to be from the heater core.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Water starting to drip from right side under the dash? [Re: HemiRick] #1058589
08/21/11 01:31 PM
08/21/11 01:31 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If it's an a/c car check the drain tube. If not a/c I will have to agree on the heater core being the problem.
Re: Water starting to drip from right side under the dash? [Re: stumpy] #1058590
08/21/11 01:39 PM
08/21/11 01:39 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
or wiper post seals. was it raining or just washed?
Re: Water starting to drip from right side under the dash? [Re: stumpy] #1058591
08/21/11 01:41 PM
08/21/11 01:41 PM
Morgantown, WV
Morgantown, WV
The car does not have AC and it was not raining.
Re: Water starting to drip from right side under the dash? [Re: 1970 Drop Top] #1058592
08/21/11 01:44 PM
08/21/11 01:44 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
sorry then it's your heater core leaking.
you could clamp both heater hoses, so it won't leak while you finish driving the car this year.
I suspected my heater water valve was internally leaking, allowing some hot water to go through the heater core while I was running the AC. So clamped them off temporally. I used 2 old water bed wood frame brackets I had laying around. Looks like crap but works.
You could do something similar until you take out the heater box to replace the core. Good luck.
Re: Water starting to drip from right side under the dash? [Re: 1970 Drop Top] #1058593
08/21/11 08:56 PM
08/21/11 08:56 PM
scratchnfotraction Offline
does it taste sweet like antifreeze?
i just tested my sons water leak like that this weekend,he thought it was rain,i walked out and tasted it said nope..antifreese,block the heater dry the carpet
CSI would have done it that way,,i am sure of it
Re: Water starting to drip from right side under the dash? [Re: scratchnfotraction] #1058594
08/22/11 12:11 AM
08/22/11 12:11 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I remember Cheech and Chong did a skit like that when they found a pile of dog doo on the street....
Re: Water starting to drip from right side under the dash? [Re: screamindriver] #1058595
08/22/11 12:15 AM
08/22/11 12:15 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Instead of tasting it, if there's antifreeze in the system, the liquid will feel a bit oily. There's also a water drain for the cowl that can get plugged up, in which case rainwater & car-wash water will come out of the heater box.
