Clutch fans..What's the difference..................... #1058111
08/20/11 09:34 PM
08/20/11 09:34 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
The reason why I ask, is that I'm thinking of putting that style in my 86 RC that was factory with the 360 the 80's style radiator. But I have a 446 motor in it now, and was wondering if I should get one for a Big block or one that fits the cooling system for that year/360?
Moparlee
Re: Clutch fans..What's the difference..................... [Re: Robbins] #1058112
08/20/11 09:50 PM
08/20/11 09:50 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
pretty sure the bolt pattern would be different. you'd have to go with the BB one but would you have the water pump to radiator clearance?
Re: Clutch fans..What's the difference..................... [Re: mikemee1331] #1058113
08/20/11 09:55 PM
08/20/11 09:55 PM
scratchnfotraction Offline
I just swaped the HD thermo clutch with 7 blade fan from my 85 SB to the 440 in the 88 truck.
just order a HD max cooling thermo clutch for a mid 80s dodge truck,I use an 86 3/4 ton for the counter jerk to key in.
for an upgrade in rad capacity the 86 3/4 ton has a rad thats the same size wide and bolts in but is 2-3 inches taller,has its on metal fan shroud.
the differance is one is thermocoupler and one is viscus fluid
you want the one with the spring coil on the front
I would up to a 7 blade fan on the 446 as well.
Re: Clutch fans..What's the difference..................... [Re: scratchnfotraction] #1058114
08/20/11 10:26 PM
08/20/11 10:26 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i really need to get out of the 60's............
Re: Clutch fans..What's the difference..................... [Re: scratchnfotraction] #1058115
08/21/11 12:30 AM
08/21/11 12:30 AM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
"counter jerk"
Facts are stubborn things.
Re: Clutch fans..What's the difference..................... [Re: larrymopar360] #1058116
08/26/11 06:11 PM
08/26/11 06:11 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Ok, guys this is what's on it now. Which looks to be a factory style five blade flex fan? I'm not sure if I can get another three inches of Radiator in my RC. Would it darn near be sitting on the core support or is it taller also? Mines 26 X 18 X 2, three core.
Moparlee
Re: Clutch fans..What's the difference..................... [Re: Robbins] #1058117
08/26/11 06:12 PM
08/26/11 06:12 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Do you think that this is would be better, it's what I got laying around? Scratchin, you were talking a 7 blade, but I did notice that there is a six blade aftermarket fan from amazon .
Moparlee
Re: Clutch fans..What's the difference..................... [Re: Robbins] #1058118
08/26/11 08:45 PM
08/26/11 08:45 PM
IN
ahy Offline
ahy  Offline
IN
The clutch in the pic is the thermal type which is considered most preferred. Depending on the rest of the cooling system, the 5 blade fan may do just fine in your app. Bouchillon sells a 6 blade that they swear by... may be the same as the one in Amazon.
Personally, I'd go ahead and use the clutch and fan pictured. There is a good chance it will work great. If you do need more fan, look for a 7 blade in the JY. I have a big 7 blade from my '78 Cordoba core BB engine. I don't use it because the 5 blade "low drag" that comes with the MP kit works great in my setup.
Re: Clutch fans..What's the difference..................... [Re: ahy] #1058119
08/26/11 11:04 PM
08/26/11 11:04 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
Will small and big block fans interchange? Were the 7 blade fans used on any newer cars or trucks from the 1980's or 90's?
Re: Clutch fans..What's the difference..................... [Re: ahy] #1058120
08/26/11 11:25 PM
08/26/11 11:25 PM
Arizona
az426john Offline
az426john  Offline
Arizona
The 5 blade pictured looks like the Mopar Performance unit that I have run on my 67 GTX in Arizona with no problems.
Re: Clutch fans..What's the difference..................... [Re: QuickDodge] #1058121
08/26/11 11:37 PM
08/26/11 11:37 PM
IN
ahy Offline
ahy  Offline
IN
I haven't done the switch but I'm pretty sure SB and BB in the same general time period interchage. I can't imagine Chrysler would tool up different setups. More than one have posted that the MP 5 blade fan (that I'm using on a BB) was a mid-70's early 80's offering on 360's.
Re: Clutch fans..What's the difference..................... [Re: ahy] #1058122
08/27/11 06:01 AM
08/27/11 06:01 AM
yes SB and BB fan should swap
I got my JY 7 blade fan from an AMC Hornet,bolted right to the HD thrmo clutch and have had it on the SB and BB.
any clutch fan blade should bolt to the mopar clutch,IIRC
the 86 3/4 ton truck rad is taller and uses a metal fan shroud
it will bolt right in like the one you have but the top is above the core support,it has room under the hood and fills it up.
check your fan size as the AMOZON one is 19.5"...want to make sure it fits in the shroud...measure the mech fan balde thats on there and use it as a guide
Re: Clutch fans..What's the difference..................... [Re: az426john] #1058123
08/27/11 10:20 AM
08/27/11 10:20 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
That 5 blade pictured looks like a broken seven blade fan.
That thing could not possibly be balanced.
Re: Clutch fans..What's the difference..................... [Re: Commando1] #1058124
08/27/11 10:28 AM
08/27/11 10:28 AM
IN
ahy Offline
ahy  Offline
IN
Looks sort of funny but that's how they are made. Apparantly uneven spacing prevents annoying resonance (noise and stress). The pair of two blades is close together vs the group of 3 that's spread out so it does balance.
Re: Clutch fans..What's the difference..................... [Re: ahy] #1058125
08/27/11 11:59 AM
08/27/11 11:59 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Thanks again, guys what are some of the ways to see if they are good or as far as the clutch goes. After it get to temperature and you shut it off should be able to turn it or should it be locked up? Thanks again for you guy's input.
Moparlee
Re: Clutch fans..What's the difference..................... [Re: Robbins] #1058126
08/27/11 12:19 PM
08/27/11 12:19 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Also has anybody used one of these. flex-a-lite 5656
Moparlee
Re: Clutch fans..What's the difference..................... [Re: Commando1] #1058127
08/27/11 01:19 PM
08/27/11 01:19 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
Lol. That's the performane 5 blade. It's better like that. Mo power
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: Clutch fans..What's the difference..................... [Re: ahy] #1058128
08/28/11 12:23 AM
08/28/11 12:23 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Fans are designed with uneven blade spacing for partial noise cancellation by combining low density with high density sound waves.
The thicker fan hub is made of the same grade of fatigue resistant steel as wheels. I used to sell the fan hub steel to one of the largest fan makers, Schwitzer of Rolla, MO, when lots of cars still had V8s with belt driven steel fans, rather than sideways engines with electric driven plastic ones.
Re: Clutch fans..What's the difference..................... [Re: Robbins] #1058129
08/28/11 03:27 PM
08/28/11 03:27 PM
look for greese around the shaft and clutch.
see if it will wobble with hands at 9 and 3 while its bolted up.
FSM said replace with a known good one
as far as them spining,it will vary by temps..some times it will spin a few times when shut down,sometimes it stops right away
some times spins ez by hand some times has a drag to it by hand when cold.
Re: Clutch fans..What's the difference..................... [Re: scratchnfotraction] #1058130
08/28/11 09:04 PM
08/28/11 09:04 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Thanks. Those five blade fans are quite that's for sure. It's funny when it does kick in(clutch fan) you can tell cause you can feel the heat from it standing from the side with you head under the hood. I think that I'm going to get that HD unit from Flex a lite to see and then maybe look into electric fans. Either a helper fan like my 2002 Dakota has or total electric set up.
It helped some going to this fan, but didn't totally get what I was after.
