E body convertible rear seat #1057534
08/19/11 07:36 PM
08/19/11 07:36 PM
Grand Rapids MI
N
N9671X2 Offline OP
N9671X2  Offline OP
N
Grand Rapids MI
Is the bottom rear seat in an e body convertible different than the hard top? I know the rear upper is different. I noticed the rear upper for a vert is reproduced but not the bottom, that is what has me wondering.
Re: E body convertible rear seat [Re: N9671X2] #1057535
08/19/11 07:40 PM
08/19/11 07:40 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Yes it's narrower than a reg rear seat to allow room for the fiberglass top mechanism covers.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: E body convertible rear seat [Re: HemiRick] #1057536
08/19/11 08:07 PM
08/19/11 08:07 PM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
Convertible seat frames are hard to find and are usually expensive. If you already have the top part,you may be able to cut down a hardtop lower section to fit. I have the one from my wifes car in my loft. I could probably give you the demensions of it on Sunday. I'll be out in the garage then.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: E body convertible rear seat [Re: chargervert] #1057537
08/20/11 08:32 AM
08/20/11 08:32 AM
Grand Rapids MI
N
N9671X2 Offline OP
N9671X2  Offline OP
N
Grand Rapids MI
Thanks guys, I thought they were different, but was second guessing that idea when I saw only the upper part was reproduced. Surprised they would do that part and not the bottom when that would be way more apt to rust.
Re: E body convertible rear seat [Re: N9671X2] #1057538
08/20/11 10:22 AM
08/20/11 10:22 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
it has been 15 years sence i have worked on a Ebody convert. so i am probably wrong.
yes the top 1/2 of the seats are different.
but i was under the impression that the bottom is the same between the converts and hard tops. the top doesn't go that far down to require a different width.
perception is 90% of reality
Re: E body convertible rear seat [Re: Mr T2U] #1057539
08/20/11 11:32 AM
08/20/11 11:32 AM
chargervert Offline
chargervert  Offline
The rear interior panels sweep out further on each side to clear the arms and pistons of the convertible top mechanism,so the seat demensions were shortened in width to fit in the smaller area.
Re: E body convertible rear seat [Re: N9671X2] #1057540
08/20/11 01:22 PM
08/20/11 01:22 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
1 of 2
Down to just a blue car now.
Re: E body convertible rear seat [Re: 68HemiB] #1057541
08/20/11 01:23 PM
08/20/11 01:23 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
2 of 2
Re: E body convertible rear seat [Re: 68HemiB] #1057542
08/20/11 01:39 PM
08/20/11 01:39 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
The bottom attaching points on the (white - Challenger) convertible & hartop (black - 'Cuda) interior panels are the same.
Re: E body convertible rear seat [Re: 6bblgt] #1057543
08/20/11 01:40 PM
08/20/11 01:40 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
& are the same width.
Re: E body convertible rear seat [Re: 6bblgt] #1057544
08/20/11 01:46 PM
08/20/11 01:46 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I believe there were two seat bottoms in '70, but somewhere along the way the hardtop version was discontinued & the convertible version was used on everything thru '74. The early difference was in the rear corners - hardtops had corners & the covertibles had a welded in "half-horseshoe" on each side. Here's the "horseshoe" that a convertible needs.
