Re: E body convertible rear seat
[Re: N9671X2]
#1057535
08/19/11 07:40 PM
08/19/11 07:40 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Yes it's narrower than a reg rear seat to allow room for the fiberglass top mechanism covers.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#1057536
08/19/11 08:07 PM
08/19/11 08:07 PM
Posts: 15,995 RI Deep in the rust belt
chargervert
Convertible seat frames are hard to find and are usually expensive. If you already have the top part,you may be able to cut down a hardtop lower section to fit. I have the one from my wifes car in my loft. I could probably give you the demensions of it on Sunday. I'll be out in the garage then.
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
[Re: N9671X2]
#1057538
08/20/11 10:22 AM
08/20/11 10:22 AM
Posts: 4,921 new berlin wisconsin
Mr T2U
it has been 15 years sence i have worked on a Ebody convert. so i am probably wrong. yes the top 1/2 of the seats are different. but i was under the impression that the bottom is the same between the converts and hard tops. the top doesn't go that far down to require a different width.
perception is 90% of reality
[Re: Mr T2U]
#1057539
08/20/11 11:32 AM
08/20/11 11:32 AM
chargervert
The rear interior panels sweep out further on each side to clear the arms and pistons of the convertible top mechanism,so the seat demensions were shortened in width to fit in the smaller area.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
