How would you go about fixing this hack job? #1054204
08/16/11 08:27 PM
08/16/11 08:27 PM
Oakley CA
69charger440_6pa Offline OP
Oakley CA
Picked this car up a few years ago for some parts. However I have been thinking about trying to save it. At some point someone cut off the roof and butt welded a replacement. Does anyone think this is repairable?
1969 Charger R/T under construction
2014 Ram 3500 Cummins
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: How would you go about fixing this hack job? *DELETED* [Re: 69charger440_6pa] #1054205
08/16/11 08:55 PM
08/16/11 08:55 PM
Rapid City, South Dakota
six-pack-mopar Offline
Post deleted by six-pack-mopar
Re: How would you go about fixing this hack job? [Re: six-pack-mopar] #1054206
08/16/11 09:04 PM
08/16/11 09:04 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
looks like alighnment wasn't their worry. Id probably cut it off again and start from scratch. you could maybe reuse the roof skin if it isn't butchered too bad, otherwise, AMD sells skins. as always, when your redoing it, always prep the area as best as you can before you weld the skin back on.
btw, roof skins really arn't that bad. Id say a lot easier to do than a 1/4 panel.
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: How would you go about fixing this hack job? [Re: 69charger440_6pa] #1054207
08/16/11 09:06 PM
08/16/11 09:06 PM
PNW
Danan Offline
Danan  Offline
PNW
How does the roof itself look? Rust? Dents? Is it on straight? From what you show in the pics it looks like somebody did a poor job of tacking the roof on, but it doesn't look insurmountably hateful. If you were to blast those seams clean and dress the metal with a grinder (inside framework and outside sheetmetal), it looks like you could finish the welds. The previous 'bodyman' didn't do you any favors, but looks salvageable from here..
Re: How would you go about fixing this hack job? [Re: mopars_1] #1054208
08/16/11 09:12 PM
08/16/11 09:12 PM
Oakley CA
Oakley CA
I already figured I would be doing the roof skin and full quarters that's not realy the problem. The issue is that they cut through the roof frame. Would it be structuraly ok to butt weld the roof structure at the c piller and a pillars?
BTW it's a R/T car 440 auto pp1 red, black top interior and stripe so I feel it's worth a little effort to try and save it.
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: How would you go about fixing this hack job? [Re: 69charger440_6pa] #1054209
08/16/11 09:40 PM
08/16/11 09:40 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
It has to be saved for sure. I would just weld up the roof frame where they cut through it before I did anything else. Looks to me like getting rid of the surfacr rust and cleaning everything up will be the hardest part of the job.
I think people generally will put an insert inside of the A-pillar and weld both pieces to it (you would weld the insert to the bottom of the pillar first, then drop the roof down and weld the top portion to it).
Sheldon
Re: How would you go about fixing this hack job? [Re: 69charger440_6pa] #1054210
08/16/11 09:43 PM
08/16/11 09:43 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Are you saying that instead of skinning the roof they cut it all the way through the A and C pillars? Then welded it back together?
Re: How would you go about fixing this hack job? [Re: Morty426] #1054211
08/16/11 09:48 PM
08/16/11 09:48 PM
Oakley CA
Oakley CA
Yes that's exactly what was done.
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: How would you go about fixing this hack job? [Re: 69charger440_6pa] #1054212
08/16/11 09:59 PM
08/16/11 09:59 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
That's what vinyl tops and headliners are for!
After seeing the other welds and you mentioning that you are going to reskin anyway, why not?
Get all the rust off, deskin it, weld all the past sins up and install new skin.
Boy, that was easier to type than it will be to do....
Re: How would you go about fixing this hack job? [Re: RodStRace] #1054213
08/16/11 10:18 PM
08/16/11 10:18 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
AMD se what they sell and buy every part you can to fix it properly rather than patching rot.
Re: How would you go about fixing this hack job? [Re: RodStRace] #1054214
08/17/11 01:05 AM
08/17/11 01:05 AM
Oakley CA
Oakley CA
[quote
Those were my thoughts on the issue. I guess what I'm worried about is the strength of the c-pillar and a-pillar being butt welded, but hot rod guys do that all the time.... Same concept as chopping the top.
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: How would you go about fixing this hack job? [Re: 69charger440_6pa] #1054215
08/17/11 01:08 AM
08/17/11 01:08 AM
People's Republic of Kali
70runner Offline
70runner  Offline
Yea, just get all that corroded metal around the welds squared away. If you're concerned about the butt welding strength, perhaps use a backing plate spot welded to both sides for reinforcement.
Re: How would you go about fixing this hack job? [Re: 69charger440_6pa] #1054216
08/17/11 03:14 AM
08/17/11 03:14 AM
md
W
wicked Offline
wicked  Offline
W
md
Those joints should not be butt welded like that through several layers of metal and the joints should be staggered. It looks as if just the skins were welded, and you really need to see the inner stuff to know whats going on. Once you cut it apart I have a feeling the inner pieces are going going to be short.
Re: How would you go about fixing this hack job? [Re: wicked] #1054217
08/17/11 11:01 AM
08/17/11 11:01 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
dang. if they cut all the way through the pillars and welded an entire new roof on that way...i would spit the roof panel from the frame structure, fix the frame structure by itself, adding reinforcement plates over the joints as needed and doubleing the welds, doing lots of tack welds till you have a continuous welded seam.
then toss the skin back on.
and add subframe connectors for insurance
I'm probalby going to be pulling the skin off my Cuda soon. I'm neck deep in a quarter panel replacement right now, and I'm in the process of fixing all the soft spots under the quarter. the other day though, I needed motivation. I tossed the quarter in place, and thought it looked great. I can't wait to get it done now!
I'm not after a 100 point restoration show car. I'm just killing the rust, and building a structurally sound, good looking cruiser/driver.
**Photobucket sucks**
Re: How would you go about fixing this hack job? [Re: 69charger440_6pa] #1054218
08/17/11 12:12 PM
08/17/11 12:12 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
But those chopped top cars are on full frames , not unibodies where the roof is part of the structure.
Re: How would you go about fixing this hack job? [Re: 69charger440_6pa] #1054219
08/17/11 12:16 PM
08/17/11 12:16 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I've had a lot of Chargers and torsional ridgidity is not their strong suit. If it was me I'd fix it right if the car was worth it. The big problem is you need to make sure the car is true.
I would peel it back like an onion. I would remove the quarters and the old roof. Build a brace to hold the car in a true position and then rebuild the roof understructure with good pieces. Then fit new quarters and roof skin - then spot weld or plug weld them on.
This is not an amatuer job.
Good luck.
Re: How would you go about fixing this hack job? [Re: Morty426] #1054220
08/17/11 06:18 PM
08/17/11 06:18 PM
SHELBY TWP,,MICHIGAN
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
buy all new metal from AMD.
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: How would you go about fixing this hack job? [Re: 72N96RR] #1054221
08/17/11 07:45 PM
08/17/11 07:45 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
And then hope it fits
Re: How would you go about fixing this hack job? [Re: Morty426] #1054222
08/17/11 09:35 PM
08/17/11 09:35 PM
Greenville, N.C.
BarrsRestoration Offline
Greenville, N.C.
Just how well do the AMD Charger roofs and quarters fit? Also wondering about the rear deck filler panel fit.
Re: How would you go about fixing this hack job? [Re: JohnRR] #1054223
08/18/11 01:20 AM
08/18/11 01:20 AM
State of retirement
52savoy Online content
52savoy  Online Content
State of retirement
I've seen first hand what happens when the pillars are cut through without a jig. The unibody springs out of shape and getting it back is almost impossible. Get a frame chart and put it on a jig before even starting. Jigs are available for a reasonable price....
http://www.accessiblesystems.com/subframe/subframe.php
hopefully the front and back glass openings weren't screwed up to much.
