Help with 340 Thermoquad idle circuit not working #1052983
08/14/11 06:53 PM
08/14/11 06:53 PM
Stuart, FL
Grassosgarage Offline OP
Stuart, FL
I have a rebuilt T-Q on a relatively stock 340. I rebuilt it and The carb is super responsive, secondaries work great, no leaks, but I cant get the idle circuit to work the motor just runs out of fuel under about 1100 rpm. I'm sure something is clogged up but not sure how the idle circuit works on this carb or what to look for. Anybody know?
'70 Cuda 440/auto
'70 Duster 340/4sp project
'70 Satellite convert 318 survivor
Re: Help with 340 Thermoquad idle circuit not working [Re: Grassosgarage] #1052984
08/14/11 09:49 PM
08/14/11 09:49 PM
What's the idle speed? It just will not idle? Might shoot a 2 second shot of starting fluid in each idle mixture port (count # of turns to easily return them to orig)
Re: Help with 340 Thermoquad idle circuit not working [Re: RapidRobert] #1052985
08/14/11 09:53 PM
08/14/11 09:53 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Which TQ do you have (what is the number stamped into the drivers rear foot)?
It sounds like Roberts on the right track, your idle mixture screws do nothing if your rpm is to high and the primary circuit is doing it's thing. Have you checked your timing?
Are you 100% certain you do not have a vacuum leak?
Re: Help with 340 Thermoquad idle circuit not working [Re: ScottSmith_Harms] #1052986
08/14/11 10:04 PM
08/14/11 10:04 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
x2 on what RR and SH says ..
ALSO .. check to see at what RPM your primary circuit comes in.
