68 Coronet RT restoration questions #1052226
08/13/11 07:40 PM
08/13/11 07:40 PM
Arizona
68CoronetRT Offline OP
Arizona
1. Did early 4 speed cars only have one coat hook?
Mine appears to have come that way from the factory and was a November 67 built car. There is a hook on the driver's side only.
2. When installing the carpet does the driver's side vinyl (heel pad?) extend up to the gas pedal or under the gas pedal?
Thanks in advance.
Re: 68 Coronet RT restoration questions [Re: 68CoronetRT] #1052227
08/13/11 10:20 PM
08/13/11 10:20 PM
Tallmadge, Ohio
P
Paul_B Offline
Paul_B  Offline
P
Tallmadge, Ohio
The original carpet in my 68 Coronet had the carpet heal pad positioned under the gas pedal.
Re: 68 Coronet RT restoration questions [Re: 68CoronetRT] #1052228
08/13/11 10:27 PM
08/13/11 10:27 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
2 coat hooks and the gas pedal is on the corner of the heel pad. There should be a cutout on the bottom and there is a hard 1/2" thick styrofoam spacer uner the pedal.
Re: 68 Coronet RT restoration questions [Re: RoadRunnerJD] #1052229
08/13/11 10:32 PM
08/13/11 10:32 PM
Arizona
Arizona
Thanks guys. I'll check under the heel pad for the cut out.
Now where did all my energy go? LOL
Re: 68 Coronet RT restoration questions [Re: 68CoronetRT] #1052230
08/13/11 10:42 PM
08/13/11 10:42 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Original carpet...
Re: 68 Coronet RT restoration questions [Re: 1_WILD_RT] #1052231
08/14/11 12:18 AM
08/14/11 12:18 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Original carpet...
Original carpet makes the correct templete. All those cutouts are there for a reason. Little stuff like that makes a repro carpet look much more OE and really makes the underdash detailing stand out.
Someone should sell a correct templete. Or sell it with the carpet. Or have it so others can download it.
Buying this most OE correct carpet and not cutting it out like factory is like taking one step foward and one step back.
Re: 68 Coronet RT restoration questions [Re: autoxcuda] #1052232
08/14/11 09:40 AM
08/14/11 09:40 AM
Arizona
Arizona
Yes the picture helps a bunch and the template idea is excellent.
I should have paid closer attention to my original carpet when I removed it but at the time I planned on storing it. A couple of years later I threw it out - big mistake.
