Paint guys: help with fisheyes #1052149
08/13/11 04:46 PM
08/13/11 04:46 PM
midwest
I
intragration Offline OP
I
midwest
I am having an unusual problem, it seems to be getting worse. Whenever I paint anything lately, I seem to get a lot of fisheyes on it, I can't figure out what I'm doing wrong. I never used to have this problem. This is in a relatively clean garage. I've used denatured alcohol or acetone as surface prep. I haven't been doing any detailing or using any silicone products. I do wear neoprene gloves, without powder. Tools and sandpaper have not been contaminated with anything. Any thoughts on this? Should I be prepping with something else? I've used grease and wax remover, but it seems to evaporate much more slowly. I recently painted a part, it fisheyed. Cleaned it with Acetone, tried again, more fisheyes in the same places. Tried again, same thing. Any ideas? Thanks.
Re: Paint guys: help with fisheyes [Re: intragration] #1052150
08/13/11 05:12 PM
08/13/11 05:12 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
...One thought is to make sure the compressor is'nt sending any oil/contaminants through the line...Even a small amount will cause big troubles... Are you heating the garage ??? Could be some type of airborne contaminants related to that ...What about the gun ??? Good and clean ??? Used any lubricants on it ??? Depending on what you're spraying you can add the fisheye eliminator but you'd be masking the real problem and it may not even do the trick depending on what the trouble really is...
Re: Paint guys: help with fisheyes [Re: screamindriver] #1052151
08/13/11 05:33 PM
08/13/11 05:33 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
That was my thought... Petroleum getting in the paint... WD40 or other light lube on the gun? Oil from compressor in the lines? But, I'm no painter, only done 2 projects do far and haven't had any fisheyes
**Photobucket sucks**
Re: Paint guys: help with fisheyes [Re: 70Cuda383] #1052152
08/13/11 06:00 PM
08/13/11 06:00 PM
I would have to agree with the oil particles or products of combustion getting into the paint. If that is not the case and your place and tools are free and clear of that stuff, I would think it would have to be a reaction with the prior paint on the part. Is this happening with a bare metal piece or when you are applying the color over the primer?
Re: Paint guys: help with fisheyes [Re: 70Cuda383] #1052153
08/13/11 06:05 PM
08/13/11 06:05 PM
md
W
wicked Offline
wicked  Offline
W
md
go back to wax and grease remover, it dries slower so you put on wet with one towel and dry with another,stuff that dries too fast doesn't let you wipe the contaminants off. you could be leaving contaminants during sanding that the degreaser won't touch, such as a hand lotion/cleaner you might be using, the source of fisheyes can be frustrating, some one spraying armour all or wd from 500 feet away can do this. Have to be more specific,over the whole panel, isolated areas, over primed areas?
What filtration do you have on your compressor? You useing a dessicant drier at the gun also?
Re: Paint guys: help with fisheyes [Re: wicked] #1052154
08/13/11 07:46 PM
08/13/11 07:46 PM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
Agree completely. Also make sure you are not spraying Armor-all or similar products anywhere near the paint booth. That stuff is fish eye city.
Re: Paint guys: help with fisheyes [Re: 68CoronetRT] #1052155
08/13/11 09:17 PM
08/13/11 09:17 PM
midwest
I
I
midwest
I'm sorry to say that I'm an ultra amateur, but in this case, it simplifies troubleshooting, because I'm talking about rattle cans. (see attachment of previous project car, rattle cans aren't THAT bad for small areas...) Different cans, different types of paint, sometimes paint, sometimes even the primer fisheyes. There's definitely no Armor All being used. I think the suggestion to use the grease remover and then wipe it off is probably my next step. I use a lot of acetone or alcohol, but it does evaporate quickly, so it may not be working. I'll give the grease remover a shot next time I'm painting and report back. Thank you very much.
Re: Paint guys: help with fisheyes [Re: intragration] #1052156
08/13/11 09:30 PM
08/13/11 09:30 PM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
Unless you are having them specially mixed by a jobber those rattle cans are not really compatible with the factory paint on the car.
I have a feeling you already know that.
Re: Paint guys: help with fisheyes [Re: 68CoronetRT] #1052157
08/13/11 10:01 PM
08/13/11 10:01 PM
md
W
wicked Offline
wicked  Offline
W
md
I totally agree.
Re: Paint guys: help with fisheyes [Re: intragration] #1052158
08/14/11 12:50 AM
08/14/11 12:50 AM
Jacksonville Florida
elitecustombody Offline
First step to a better finish is to stop using acetone,because it leaves film and it also can re-active,break down the substrate,use prep solvent,wax & grease remover. Second, some pruducts are just not compatable,especially when applied very heavy.But you have to be seriously doing something wrong when you manage to have fish-eyes with rattle can paint.
Re: Paint guys: help with fisheyes [Re: elitecustombody] #1052159
08/14/11 01:21 AM
08/14/11 01:21 AM
KS
68SportSatvert Offline
KS
Not sure where you are exactly but first question I would ask is if your garage is climate controlled. Thing to remember is it has been VERY hot in many areas this summer...hotter than usual. That coupled with higher humidity my be the culprit.
Re: Paint guys: help with fisheyes [Re: intragration] #1052160
08/14/11 03:27 PM
08/14/11 03:27 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
What brand paint are you using. I had the same exact problem last week with Krylon. It kept getting fisheyes in the paint. I then went and bought some Rustoleum and the problem stopped.
Re: Paint guys: help with fisheyes [Re: Steve340] #1052161
08/14/11 04:46 PM
08/14/11 04:46 PM
midwest
I
I
midwest
Very interesting, I am ALSO using Krylon... I've had really good experience with it up to this point, I still think this may be a prep issue and not a paint issue. No climate control of any kind in the garage. As for the compatibility of that paint in the picture, I did have it specially mixed, it was just Centari put into rattle cans. It will never match exactly, but it can get pretty close.
Re: Paint guys: help with fisheyes [Re: intragration] #1052162
08/14/11 07:46 PM
08/14/11 07:46 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
I had been using an old can of Krylon that was over a year old and it worked fine. When I ran out of paint and went to get new paint, that's when the problem started.
Re: Paint guys: help with fisheyes [Re: Steve340] #1052163
08/14/11 10:47 PM
08/14/11 10:47 PM
New Jersey
W
Wild_Hemi Offline
Wild_Hemi  Offline
W
New Jersey
Fish eye, If your using an air compressor make sure your oil does not have defoamer in it. It usually is Silicone based and sprays in the air when compressor is running. They add it to oil.
Re: Paint guys: help with fisheyes [Re: Wild_Hemi] #1052164
08/14/11 11:54 PM
08/14/11 11:54 PM
he's using rattle can paint,not spray gun and air compressor
Re: Paint guys: help with fisheyes [Re: elitecustombody] #1052165
08/15/11 04:39 AM
08/15/11 04:39 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I read a post on DodgeCharger.com about this. The OP was also having problems with Krylon. He said that he contacted Krylon directly and learned that due to EPA regulations, the formulas for their paints had to be changed. Maybe this explains why the old stuff worked and the new stuff sucks. Yaaaay Environmental weenies!
Re: Paint guys: help with fisheyes [Re: elitecustombody] #1052166
08/15/11 07:16 PM
08/15/11 07:16 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
First step to a better finish is to stop using acetone,because it leaves film and it also can re-active,break down the substrate,use prep solvent,wax & grease remover. Second, some products are just not compatible,especially when applied very heavy.But you have to be seriously doing something wrong when you manage to have fish-eyes with rattle can paint.
I agree with this also the reason the wax grease remover and or prep takes awhile to dry is you apply it and then wipe it off with a second clean white rag while still wet so you remove what was dissolved
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Paint guys: help with fisheyes [Re: 340SIX] #1052167
08/15/11 08:31 PM
08/15/11 08:31 PM
O
OLD318 Offline
OLD318  Offline
O
1. What type of substrate are you spraying over?
OEM mild steel?
hard Plastic?
Fibreglass?
cast pot metal? etc?
2. What type of finish are you spraying the rattle can
(Centari acrylic enamel) over?
Is it Original OEM paint?
- if so what is the orignal paint, lacquer, enamel, single
stage bc/cc?
Is it After market primer?
- Acryllic lacquer primer
1K urethane
2K urethane etc..
3. Have you tried the rattle cans on something else?
(to rule out contaminants in the rattle cans)
Re: Paint guys: help with fisheyes [Re: OLD318] #1052168
08/15/11 09:08 PM
08/15/11 09:08 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
I just read through all the responses and I have an idea not yet mentioned. Next time you work on prepping an item do NOT wear the gloves.
I have had one brand of gloves result in horrible fisheyes. I verified it by stripping off the paint and degreasing the part (I use lacquer thinner) WITHOUT wearing the gloves...same part, same paint, same day, no fisheyes.
Give it a try.
