Re: 604 Predator dyno session complete
[Re: camastomcat]
#1051240
08/11/11 06:30 PM
08/11/11 06:30 PM
Posts: 1,328 St. Louis, MO
mopardamo
St. Louis, MO
Hello, Able to do 200 passes and minimal spring changes pulling down 1150hp sound awesome to me. Helluva fun ride! Sounds like you got a exactly what you wanted. Great balls of fire! Let us know how the track treats you. Damon
[Re: Cab_Burge]
#1051247
08/11/11 11:37 PM
08/11/11 11:37 PM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
Did you do any pulls above 7500 RPM? It looks like it was still gaining power at the cut off RPM on the tunnel ram sheet
Really, I didn't want them to beat the heck out of it and it won't see anything over 7800-8000 in the traps. So, since I wasn't there, I can't answer that for sure, but I doubt it. When I get it in the car, I'll play with the shift points, but I'm glad it lost less than 40HP with one carb. Marcella did a great job on the intake. Maybe I'll come out to the Mopar deal at Woodburn again next year and you can come over and say hi Cab.
[Re: camastomcat]
#1051248
08/12/11 12:37 AM
08/12/11 12:37 AM
Posts: 614 new jersey
gillman34
new jersey
We could have pulled it higher but the plan was not to beat it up on the dyno. It is built with all the best parts and can surely handle the higher rpm. The time slip will tell the true tale! The puff of white smoke at the end of the pulls is steam from the water brake on the dyno,yes the water gets that hot! Overall we are very happy with the results.The engine sealed up well(always a battle with an aluminum block),has great vacuum,and has a flat torque curve. I,for one,can't wait to hear how it performs in the car!!!
[Re: gillman34]
#1051249
08/12/11 12:43 AM
08/12/11 12:43 AM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
Nice! Hey Steve, give me a call next time you plan on running one of those. I'd be interested to come out there and check it out...
MB
[Re: gillman34]
#1051250
08/12/11 12:46 AM
08/12/11 12:46 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Nice job Steve How ya been?
RIP Monte Smith
[Re: gillman34]
#1051251
08/12/11 12:47 AM
08/12/11 12:47 AM
Posts: 698 Alberta Canada
Edge
Alberta Canada
Motor sounds great and torque curve is nice and flat, will be very interesting to hear how your car performs by comparision to the B1 engine your were running before IIRC. Best of luck to you the predator is a very nice top end. Are you changing convertors or is the torque similar enough I am wondering if you will need a tighter converter ?
76 Duster
work in progress
[Re: camastomcat]
#1051256
08/12/11 12:30 PM
08/12/11 12:30 PM
Posts: 16,928 NC
440Jim
NC
The 604 CID did like the additional air flow. Was that the same tunnel ram with a single carb top? What size are the carbs?
Looks good.
