Re: Lost the tranny tonight, HELP
[Re: JonC]
#1048348
08/07/11 03:01 PM
08/07/11 03:01 PM
Posts: 75,028 U.S.S.A.
JohnRR
U.S.S.A.
A 727 You can buy a good convetor and HD pump gears , you'll need a new front pump more than likely . If you want to stay with a 904 for less HP loss you could look for a 998 which was put behind the 360's , 5 clutch front and I think rear clutches and other HD parts .
[Re: JonC]
#1048349
08/07/11 03:03 PM
08/07/11 03:03 PM
Posts: 7,863 Colorado
Leadfoot
Colorado
I won't be able to pull the tranny for a couple of weeks. What would make the pump tangs fail??
A 340 in front of it.
[Re: stumpy]
#1048350
08/07/11 03:04 PM
08/07/11 03:04 PM
Posts: 3,623 Millinocket, Maine
JonC
Millinocket, Maine
I don't have a 727, could I replace the parts with stronger aftermarket ones?
[Re: JonC]
#1048352
08/07/11 03:05 PM
08/07/11 03:05 PM
JohnRR
U.S.S.A.
You could.
How far up is millinoket ? I have a smallblock 727 I'm getting tired of moving around
[Re: RobX4406]
#1048358
08/09/11 11:03 AM
08/09/11 11:03 AM
JohnRR
U.S.S.A.
You don't have to be concerned with a front drum detonating on you with a 904... unlike the 727.
Why is that ? the design is the same just smaller,
Does the smaller size of the drum stop it from coming apart , it's made of the same material ? The outer race of the 904 is riveted to the case , but does it have more rollers like the later OD based trans and which would cause it to never roll over ?
I want to learn here ...
[Re: JohnRR]
#1048360
08/09/11 04:48 PM
08/09/11 04:48 PM
Posts: 25,831 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Does the smaller size of the drum stop it from coming apart , it's made of the same material?
Yes, the drum flies apart due to centrifugal force and the smaller diameter drum generates less centrifugal at the same rpm.
The outer race spinning in the case is the least common form of failure, failure of the internal elements is the most common but sprag failure in a 904 is less likely to cause an explosion.
[Re: JohnRR]
#1048361
08/09/11 05:29 PM
08/09/11 05:29 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
Yes, as John K mentioned, it's the physical size of the drum unit.
The 727 Drum comes apart in the 12000-13500 RPM range and the 904 unit doesn't come apart until almost 23,000 rpm. 23,000 is pretty hard to reach with any street or even race small block using 2.2x input RPM. It's not hard to get the blow point with a good BB and 727 (5700ish rpm) One of the trans guys did a test, maybe TCS, and that was the findings, IIRC.
Ask 70AARCuda about his 904's.
[Re: JonC]
#1048363
08/10/11 07:30 PM
08/10/11 07:30 PM
JonC
Millinocket, Maine
I have run this transmission since 1994 when I bought the car and I don't know how long before I bought it had been run or even how it was run. It has never skipped a beat until I had my engine rebalanced because of vibration issues. I installed a B&M flexplate (that was the only mod I made except for the balance). Symptoms started right after that such as a slight rise in RPM and I would just hit the slapstick to the Drive position a little and it would cure the problem. It has done this a few times since spring when I put it back on the road. I attributed it to the modification I had done to the slapstick that TTI had said to do to get clearance for the headers. This may be just a coincidence, but now not so sure. Like I stated before the 904 has never given me any trouble until now and I have driven the car like I stole it since 94. I just have been thinking about the whole thing and the only thing that comes to mind is the B&M flexplate may not be letting the TQ engage the front pump properly. Comments welcome.
I haven't got the tranny out yet to see what's wrong and probably won't for at least a week, when I do I'll post what I find.
